Thread: Fault code P0100, AGAIN!!!
    Jul 2009
    Leicester
    Default Fault code P0100, AGAIN!!!
    Fault P0100 again
    Have had boost pipes changed, MAF sensor changed, renewed EGR last week. Could the boost sensor throw up this fault code? I have come to an end with caring about this car, she used to be so nice to me!!!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Clean the boost sensor anyway its easy to do, use carb cleaner if not use wd 40. also found these regarding the code. i guess to much air, not enough air, sensor faulty ?.
    P0100
    Mass Or Volume Air Flow Circuit High Input
    P0100
    Mass Or Volume Air Flow Circuit Low Input
    P0100
    Mass or Volume Air Flow Sensor Circuit Range/Performance
    Jul 2009
    Leicester
    have cleaned boost sensor on each repair, still no joy. Might get booked in for MAF sensor renewal again.
    Jul 2009
    Leicester
    anyone?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Have you done the air box mod ? if so try reverting it back, make sure you have a standard air filter in, could it be the maf sensor gone again ?.
    Jul 2009
    Leicester
    done the mod and reverted it. Car is booked in for another MAF sensor
    Jul 2009
    Leicester
    new maf and still a problem, could it be boost pressure sensor
    Jul 2009
    Leicester
    ??? im lost with this now
  1. fault p0100* but only when engine warmed up
    By mack in forum Engine & Drivetrain
    Last Post: 3rd July 2013, 08:38
  2. PLEASE HELP ERROR CODE p0100
    By signum_05 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th December 2012, 20:20
  3. p0100 Fault 2.2DTI 2004
    By 1TAYLOR1 in forum Engine & Drivetrain
    Last Post: 24th April 2012, 22:05
  4. Fault Code P0100
    By dhwigston in forum Engine & Drivetrain
    Last Post: 1st August 2011, 06:46
  5. Fault Code P0100
    By vectra2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th May 2008, 19:08
