Results 1 to 10 of 17
Thread: CDTI 150 Flat Spot is back!! Where is the Fuel Filter?
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default CDTI 150 Flat Spot is back!! Where is the Fuel Filter?
    The flat spot between 1k and 1.8k rpm is back on dad's CDTI 150.
    I read a thread last night, cant remember now, but someone mentioned something about changing the fuel filter.
    So my questions are:
    - where is the Fuel Filter located;
    - how easy is it to get to and replace;
    - how much am I looking at for the part;
    - is this likely to help with the problem as it also still has the slight tremble on idle!
    Oh and another thing, CDTI 150's!
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    morning g it's located on the side of the fuel tank on driver side have a look around the jack point m8 can't miss it. if never been changed like mine good luck to u my friend it is stiff as hell. part only cost about a tenner iirc from halfords. remember to depressurise the system first, plastic knob on fuel pump twist off and press with a small screwdriver to release the valve have a cloth ready to catch any fuel tho.
    Birmingham
    Sounds like a pig of a job! GREAT!! I will have a gander at it and see what I make of it. Is it relatively wasy though?
    Nov 2007
    telford,
    there is a little clip on it to stop it from moving toward the front of the car just move that and give it a bit of a twist and a pull and a kick and a punch and it should loosen up, releasing the pipes is prob the hardest part m8.
    Birmingham
    Is this a Service item? Also, could this contribute to the issue I am having?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    No, the fuel filter is under the bonnet towards the back, almost in the middle - its the large round black thing with pipes going in and out of it. You remove the pipes going in and out and it lifts up out of the bracket (although it could need a fair shove to get out) then once out the top is removed (there is diesel inside BTW) and the filter comes out, new sealing ring and new filter put back in place.
    The filter is about £22 from VX, and by all accounts its best to get a VX one.
    I think the thread you mean is the one regarding fuel/injector treatments - they can clog the filter and cause some hesitancy and misfire symptoms - does your dads still run smooth, but just sluggish, still leaning towards EGR issues..?
    Hope this helps.
    Birmingham
    Cheers Dan, cause it helps bud. Any pictures directing me towards the bleeder? Easy job? Worth doing to eliminate this issue?
    Nov 2007
    telford,
    i like to treat as a service item m8 when i do my annual service but didn't bother last year. i think it is recomended to do it every 2 years or something similar. as regard the issues ur dad is having m8 i haven't a clue if i'm honest, but changeing it can only do good m8.
    Nov 2007
    telford,
    is the filter in a different place on the cdti's to the 2.2 directs, then cause when i changed mine yesterday it is next to the fuel tank.???????
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by wanna veccy View Post
    Yes, its under the bonnet (under the 't' of the word Boost - with the blue clips).
  1. CDTI 150 Dreaded flat spot HELP!!!
    By keets in forum Engine & Drivetrain
    Last Post: 19th October 2015, 09:26
  2. CDTi-150 Flat Spot @ 1800rpm
    By Signum7060 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2012, 07:27
  3. Could this be the cause of 1.9 cdti 150 flat spot?
    By andreitone in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 18:00
  4. Bleeding Flat Spot is back! Usual CDTI 150 Suspect!!!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 19th April 2011, 17:04
  5. CDTI 150, more FLAT SPOT HELP please!
    Last Post: 7th May 2010, 23:28
