Thread: whiring, ticking and loud bangs every now and then from my gear box area 2.0dti
    Apr 2009
    stockton-on-tees
    Default whiring, ticking and loud bangs every now and then from my gear box area 2.0dti
    as above having some lovely noises i think i may have to sell my vec its ****in me off now any ideas on the noises im having gunna check the engine mounts in the morning im getting a ticking noise as im accelerating wen i let off the accelerator im getting a whiring and ticking noise and sum times wen i change gear or the engine is under load its bang quite loud :'( HELP carnt understand y they r used as taxis
    Apr 2009
    stockton-on-tees
    morning bump
    Mileage : 000
    Could it be the DMF (duel mass flywheel) falling apart.?
    Oct 2007
    nottingham
    hi yep mine is the same has been diagnosed as dmf,hotter the engine gets the louder the noise.mine is booked into garage tomorrow.
    tommy
    Apr 2009
    stockton-on-tees
    the strange thing is wen im actually moving and a put the clutch in till the rev counter is at 1000revs the noise is still there but when im stationary it is not could this still be the dmf??? gettin fuming with the ****** car now
    Apr 2009
    stockton-on-tees
    bump
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    dual mass flywheel they're much better then the 1.9 rubish but still break
    Apr 2009
    stockton-on-tees
    Well I think I've found the problem it was the thrust bearing £50 from the motor factors I'll load sum pics up once I've finished
    Regular Member pugs,signum's Avatar
    swansea
    Quote Originally Posted by barrymanalow87 View Post
    Hi did you change the thrust bearing? did it solve it?
    Mine is making same noise and after much reading on the forum iv come to think its the dmf, popped to a garage yesterday and they say it would be 5hours labour at £35 ph plus parts but dont know what parts until its taken apart as i looked on eurocarparts.com and there's 3 flywheels and 3 clutch's at different prices. :-S
  1. vectra c 1.9cdti xp2 very loud and ticking engine noise
    By atty in forum Engine & Drivetrain
    Last Post: 26th August 2012, 14:07
  2. Loud ticking/knocking
    By rob123 in forum Bodywork & Interior
    Last Post: 31st May 2010, 18:19
  3. loud whine cam belt area????
    By taxidriver50005 in forum Engine & Drivetrain
    Last Post: 6th March 2008, 20:10
  4. knocking/ticking from around cambelt area??
    By Kyser143 in forum Engine & Drivetrain
    Last Post: 12th October 2007, 20:03
  5. Loud ticking sound help !!
    By north in forum Engine & Drivetrain
    Last Post: 20th August 2007, 12:46
