Thread: piston retraction tool
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Default piston retraction tool
    anyone know where i can get one?
    ive been all over the place round here na dno one does one for a vauxhall, and if they do its part of a £70 kit.
    any help would be great,
    thanks
    carl
    Regular Member Inspektor's Avatar
    Northampton (Santa pod)
    Are you talking about the piston in the brake caliper?
    If so,a G clamp wound slowly would do the job.
    yeah, the piston in the rear brake caliper. i thought it needed to twisted and compressed at the same time.
    thanks
    carl
    indeed it does need to be twisted and compressed at the same time..
    there may be no option but to buy a kit..Thou you can use slip joint pliers if you're careful with the boot on the piston..Be aware thou that not all kits come with the 21mm adaptor to fit vectra-c..
    thanks for the help guys.
    carl
    Regular Member marichrd's Avatar
    Jun 2006
    Cheshire
    you cna get a piston wind back tool at halfords in the sykes pickavant section. about £15 - £20.
    Well it works on the ford calipers fitted to my caterham. See no reason shy it should not work on other calipers too.
    Jun 2006
    Cheshire
    do not order form the webbie in this reply. They seem mucho moolah.
    http://www.premiertoolsinternational..._Rewinder_.htm is what you may be looking for...
  1. piston rewind tool
    By brtsam1 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 20:39
  2. Piston Rewind Tool
    By Jamesx81x in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2012, 13:07
  3. Piston rewind tool
    By ickleric in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 11:28
  4. Piston Rewind tool
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 10:58
  5. Piston Wind-Back Tool...
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2008, 14:10
