Thread: Oil and filter service price
    Regular Member TonyJames's Avatar
    Sep 2009
    northants
    Default Oil and filter service price
    What should this cost at vauxhall,mines due i rang my local dealer they said 70 - 80 quid thats just to change oil and filter.They said if i want the intermediate service when they also check all the levels and brake pads is 130.Sound about right?
    Yes, but make sure they are quoting for the correct grade of oil
    Alternatively, you can supply the oil
    An interim service is quite comprehensive, not just checking the levels, but should include checking the suspension and replacing the pollen filter
    Typical cost is £150 plus VAT
    See the front section of your service book for details
    If your car is still under warranty, then you should follow the standard intervals, but you can of course add additional services, but there is little benefit
    My car is on 30K miles / 2 years service intervals, although the indicator usually only gets as far as 20K miles
    Now that the warranty has expired I am ensuring the services are every 20K miles, and from the end of this year I am swapping to a thicker synthetic oil with reduced oil change intervals of 10K miles
    Full Member paul.sessions's Avatar
    leighton buzzard
    yeah sounds about right changed my oil and filter the other day cost £42 for the oil £10 ish for the the other bits sump plug, filter.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I get my oil & filter done every 6 months or so at my local National Tyres.... costs around the £40 I think for Castrol Magnatec.
    Sep 2009
    northants
    Thanks guys i'll use vauxhall then
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Quote Originally Posted by Handyandy-UK View Post
    I too had a interim oil and filter change on my previous BMW done using National Tyre's cheap oil offer. Cost just £30,60 for Castrol Edge 5/30 fully Synthetic, I can't even buy the oil for that price. (The recommended oil for most late BM cars)
    It's a very good deal, as long as the guy you get doing it knows what he is doing, as they do have a few idiots working for them, but luckily I had no problems at all. I think even they can just about manage a simple oil change. Not worth doing it yourself with prices that cheap IMO.
    The Filters they use are made by Unipart, though I supplied a genuine BMW filter which he fitted instead, when I compared them their filter looked identical to me.
    Birmingham
    I paid 40 quid at my local garage for a oil n filter change on my cdti, at that price it aint worth the hastle of doing it yaself!
    salisbury
    do mine every 5k on the drive with some ramps, change everything air, fuel, oil and oil with semi synth and flush first with wynns engine flush total cost around £30. engine run sweet. do the same with my works 1.7tdi 51 reg astra van, just starting its 150,000 mile and running sweet. for the money and an hour it well worth it.
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    70-80 quid, think yourself lucky, my local stealers in december quoted me 140 quid for oil and filter change and a visual inspection of the brakes and fluids, which you can bet they would have found a problem with, needless to say i serviced it myself in the end, plugs ,oil and filter 5w 30 synthetic,air filter and pollen filter and all for 60 quid....they should wear striped jumper and masks....
    Regular Member Nato's Avatar
    Risca, South Wales
    I would've thought 70-80 quid is a bargain at a dealer. My local independent want 65 quid for fluid change service, using fully synthetic. I remember my old B costing me nearly 200 quid for the same service when I first bought that! Made a promise to myself then never to let the dealer near my car again!!
  1. Service price
    By mspvxr in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2009, 15:53
  2. 3rd service price
    By tyler in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 08:04
  3. price on service
    By kenp in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2008, 21:02
  4. service price
    By yorkiebar in forum Diesel Engine related
    Last Post: 5th October 2007, 11:30
  5. Service Price
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2005, 20:02
