Results 1 to 3 of 3
Thread: gearbox
    Sep 2009
    newcastle
    Default gearbox
    when i change gear from first to second gear it is really
    clunky when cold gets better when hot but is still not
    right changed gearbox oil as a precaution anybody
    got a clue what it might be.
    cheers in advance
    I think there was a field remedy that basically means putting less oil in the box. If its done a few miles it maybe that the second gear syncro may be worn.
    birmingham
    when the cars in neutral push the clutch in, then let it out and if there is a rattle it could be your clutch and fly wheel on there way out, if it goes whe you dip the clutch again then its a definate.. damn fiat parts.
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
