Thread: Misfire, injector mod already done.
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Default Misfire, injector mod already done.
    Hi, car is a cdti 150 05 plate, been having an awful misfire and today the garage said it's because the connector on the no3 injector is wrong, however i think this is only because it's had the mod and when i mentioned it they had never heard of the mod. Is there any way of testing the connector to the injector and what else could be causing the misfire? Any help greatly appreciated, really desperate now
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    If your misfire is below 2200revs or on partthrottle it could be the egr valve or swirl valves on inletmanifold check these and follow how2 on here to clean the egr mate hope this helps
    Jan 2010
    Cornwall
    Sorry forgot to say that manifold has been done, also cleaned and lubricated egr valve as per how2.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Defo an EGR issue, probably sticking.
    Jan 2010
    Cornwall
    Ok, i will do it again.
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by Gazza36 View Post
    Make sure you don't oil/grease the spring/shaft too much as this can cause sticking.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Deffo agree i tell everyone this! not grease, i use a elec contact spray after cleaning, grease can cause sticking. as ive stated many times when he EGR is parted work the spring by hand, look for the shaft part thats ONLY exposed when working the spring!!, this shaft part runs through a shroud! and i find this part NEEDS getting at and cleaning and spraying with carb cleaner, DONT lubricate after with grease cos this will attract muck after, im in the process of trying different lubricants to see which is best!, ( IM AFTER AN OLD EGR TO EXPERIMENT WITH ??)
    Jan 2010
    Cornwall
    I put a load of 3 in 1 on it, is that alright? It's still doing it, it sounds like the waste gate goes mental when it happens??
    Jan 2010
    Cornwall
    I'm going to strip it one more time and remove some of the oil and see if it makes any difference, if I buy a new egr and it doesn't work is there anything else it could be? Cheers
    Jan 2010
    Cornwall
    Now fixed, new egr sorted it.
  1. Help please....stuttering, ?misfire...3rd injector or EGR??
    By marky2027 in forum Engine & Drivetrain
    Last Post: 28th June 2012, 21:59
  2. misfire and lumpy idle since new injector
    By aidy-cdti in forum Engine & Drivetrain
    Last Post: 11th August 2011, 23:03
  3. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  4. Does the No 3 injector wiring really solve the misfire?
    By bygumlad in forum Engine & Drivetrain
    Last Post: 13th April 2009, 16:40
