Thread: lowering springs question!
    groningen
    Default lowering springs question!
    Hello,
    i have a question about lowering springs,
    for my signum cdti 150hp i can get some 30mm springs (eibach) but the springs are for an vectra c Sedan (not station)
    will the springs fit? and will they lower 30mm? or more??
    who knows the anwser on this question(s)?
    ive told the seller i will let them know asap.....
    thankx in advance
    greetings from holland!
    ciao mark
    groningen
    no one??
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    I have the eibach kit they are really good they will lower your car by 30mm or 15mm on the Sri model. I am not sure about the sedan question in uk they are estate and hatchbacks so if you have an estate hen the springs won't fit a hatch as the loads are heavier they will fit but the height will be diff I think the signum uses estate springs from the vec c
    Hope this helps
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    mine lowered a little more than 30mm i reckon.. The Eibachs I bought are for the lowest weight after checking my axle weights on the drivers door panel. Check the axle weights of the donor car and compare them to your own, if they are the same then your home free.
  1. Lowering springs question
    By m20_swe in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2012, 11:26
  2. lowering springs
    By colly in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 13:14
