Thread: Oil Pressure Solenoid Switch
    Aug 2009
    Hull
    Default Oil Pressure Solenoid Switch
    I have a suspected faulty oil pressure solenoid switch. The oil levels and seals check out fine, however just recently I have been getting an oil warning light coming on, on my 2002 2.2Sri DTi. Occasionally it comes on and then goes out after switching off the ignition and doesn't come on again for sometimes weeks later. On one occasion I had the engine management light come on and it went into limp mode for a brief period. It has been on the conmputer at the main dealer and they can't diagnose that it is the oil pressure solenoid switch at fault unless the warning light is perminantly on. Should I wait for it to fail if ever and get it sorted then or just have it replaced next service. I was also wondering if it is an easy job to do yourself and how much the sensor might cost?
    Aug 2009
    Hull
    Default Still got problems
    I still have this problem, although learnt to live with it. Starting to become a pain now especially on long journeys.
    I have bought a new switch and I am going to attempt to try and replace it myself. It isn't however where I thought it was at the front of the engine. Does anyone know where this switch is located?
    Mileage : 000
    Could it be at the back of the engine?.
    Bristol
    Vehicle : CDTI 150
    Quote Originally Posted by masj78 View Post
    On the Y22DTR engine its on the front of the sump next to the oil level sensor.
  1. Pulse Ratio Boost Pressure Solenoid Valve
    By iwtand in forum Y & Z30DT Specific
    Last Post: 12th March 2012, 19:57
  2. Oil pressure sensor switch
    By crucial in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2008, 09:15
  3. Where is the Oil pressure switch?
    By grandadwoody in forum Engine & Drivetrain
    Last Post: 30th September 2007, 16:17
y22dtr oil pressure
