Results 1 to 10 of 11
Thread: PLEASE HELP! CDTI 150 Power loss problem
    Regular Member jujitsuboy69's Avatar
    Bridgend
    Default PLEASE HELP! CDTI 150 Power loss problem
    Hi, My car is losing power about 1500rpm makes no difference if the engine is warm)
    I've checked the following:-
    - EGR - clean, and so is the MAP sensor
    - K&N panel filter has been cleaned and re-oiled (filter box is emptied)
    - The DPF has cleared its gunk out the other day,
    - Swirl valves appear to be fine
    "Caterman" box has been removed to see if there's any problems with that (havent checked on that yet)
    - Oil change to Castol Edge 5w 30 within last 2 months - and annual service not due for another 4 months
    and its returning 46MPG....
    but there is still a loss of power upon accelorating about 1500 rpm!
    any suggestions before i pull ALL my hair out?!!!!
    cheers
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    How do you know the EGR is clean..? Did you take it apart and check the solenoid operation etc..?
    3rd Injector issues can cause this also (along with some slight misfire symptoms too) - are yours blue or yellow injector plugs..?
    What do you swirl valves "look" like, are they clean or are the covered in gunk..?
    Bridgend
    Thanks for getting back to me!
    I cleaned the EGR the other week along with the MAP sensor - the solenoid works fine as far as I can tell
    They're yellow injector plugs.
    The swirl valves are clutter free - no gunk
    I'll look up advice on here regarding the 3rd injector and see if any of the problems sound familiar.
    I forgot to mention in my previous post that the engine seems to pull fine at lower speeds i.e. between gears 1-3, but not the higher gears 4-6
    Also, I use millers ecomax (aka sport4) on a regular basis, so I would hope that would keep some engine parts running smoothly, but are there any other additives anyone would recommend as well as that, perhaps injector cleaners
    cheers!
    Lancashire
    Trim : XP1
    Mileage : 66000
    Another thing is that sometimes these additives/cleaners can clog up the fuel filter, some have had this happen and rectified with a new filter added.
    Bridgend
    Not thought of that! I'll see if I check the fuel filter?!
    However, there was a new on fitted August '09 during its last service, so i'd hope its not clogged up just yet!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Try cleaning the boost sensor and the throttle body, a guide in the how 2 section will help you. also if the solenoid on the EGR has'nt been parted and cleaned ots a must!.
    Bridgend
    Ok will look into that too!
    Just got myself the 3rd injector mod kit, so shall be trying that next
    Regular Member nigec's Avatar
    barnsley
    Having same probs as you pal, ive cleaned egr valve and its clean now, boost sensors clean now, wheres the MAP sensor and whats this DPF buisness mean ?
    Power kicks in at about 1900 rpm. swirl bar is attached and is not to gunky round pots.
    Bridgend
    The MAP sensor (or boost sensor is to the left of the egr)
    http://www.vectra-c.com/forum/showthread.php?t=88845
    -thats a thread about cleaning it, I always clean that the same time as my EGR as they're so close!
    The DPF (diesel particulate filter) isnt fitted to all cars, I think all estates and signums have them as they're heavier cars - there should be several threads on here about the DPF.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by jujitsuboy69 View Post
    Oh believe me it can be. Mine went from beige to BLACK as sin in 9 months. Experienced problems after 3 days of using injector cleaner. Replace the fuel filter...it's not expensive
  1. 150 CDTi power loss
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 15th December 2011, 12:48
  2. problem with signum 2.0 dti loss of power
    By unhappy of wales in forum Vectra C / Signum Troubleshooting
    Last Post: 10th July 2011, 21:38
  3. Is this a Known Problem - Loss of Power?
    By quarkrad in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2011, 13:34
  4. 2.2DTI Power loss and starting problem
    By grslewis in forum Engine & Drivetrain
    Last Post: 21st April 2008, 16:38
  5. loss of power 1.9 CDTi
    By ALD in forum Engine & Drivetrain
    Last Post: 5th January 2007, 16:25
