Thread: Signum Brake pedal -what does yours do?
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Default Signum Brake pedal -what does yours do?
    Can someone try this on their car, please? Not sure if we have a fault or not.
    After having new pads fitted all round on the (pre-facelift 2004 3.0 CDTi Elite), I noticed something odd with the brake pedal.
    With the engine off, the pedal is solid.
    With the engine running, it's initially solid, but a good steady pressure on the pedal sees it sink slowly towards the floor. It's not losing fluid, so something must be going on with the servo.
    The brakes work perfectly well when you're driving, and give no cause for alarm, but it just seems a bit odd.
    I'll be interested to see what other folks find.
    Thanks, Phil
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    All diesels do it esp when you have fitted new pads it will take a week or so for it to settle mine did
    Irmscher Insignia CDTI 130
    Glasgow
    Perfectly normal, the vacuum only works when the engine is running hence why its hard when the engine is off.
    Luton, Beds
    Quote Originally Posted by byebyeitsagsi View Post
    /mode=Carry On
    Matron!
    Phil
    As said, normal. You get pedal creep with diesels.
    http://www.vectra-c.com/forum/showthread.php?t=74759
    Luton, Beds
    Aha, I hadn't seen that one.
    Thanks, Dave, I'm happy now. I was worried because the wife drives the car more than I do, and it was worrying me.
    Phil
    Regular Member old cruiser's Avatar
    slough
    Also used as a test to see if servo is working i.e with ignition off pump pedal until hard, keep pressure applied then start car and the pedal should be felt to sink, if this happens then servo is working.
    Cheers Pete
  2. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  3. Brake pedal ?
    By Denbo in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 01:47
  4. Brake pedal creep Signum 2.0T (not diesel)
    By olajon in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2010, 12:13
  5. brake pedal
    By barrie m in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2010, 21:21
