Thread: 2.2 Power Steering replacement
    Gloucestershire
    Default 2.2 Power Steering replacement
    On the night before we were all due to go to Devon, the power steering failed on my 2.2 SRi 52 plate. No warning, just dead on starting the car. Ended up having to hire a car whilst vx dealer took a look.
    They are telling me I need the EHPS unit replaced - £800 odd for the part plus fitting plus vat - £1200 total. Tried my local one-man-band garage, but he says because the unit needs to be programmed, has to go to vx.
    Has anyone had the same experience? If £1200 is the right price, I may end up having to scrap the car as I also need a hub assembly, exhaust and oil leak repaired - total cost more then the cars value!
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    the item will need programming but if your garage fits the part it can then be taken to vx for programming shouldnt cost more than £50 ive just had it done on mine very big job involves dropping the sub frame
    Gloucestershire
    Thanks for the info there - how long does the job take? Where did you get a new pump from?
    Apr 2008
    Wigan
    was all done warrenty matey so pump was from vx i was quite involved with it though so know the process you can however get one from a breaker but make sure it has been properly divorced with tech 2 most vx specialist breakers have this or even try ebay
    Gloucestershire
    Bump.
    Been driving round for the past few months without any power steering, but it's now MOT time, so need to get it fixed.
    Can I get a new pump anywhere other then at Vx??
    11 Post(s)
    Quote Originally Posted by APJ View Post
    http://www.bba-reman.com/catalogue/I...px?category=29
    That's of course if it's the pump and not something else wrong.
    Must be a right sod not having PAS.
    Gloucestershire
    Thanks for the info! Any thoughts on how the exchange unit gets coded to the car? Trip to Vx?
    Power steering has been playing up for about a year now, most noticeably a droning noise when switching off the ignition - bit like an aircraft turbine coming to rest! It then just died completely one night. It's fine when going straight, although parking is quite a challenge
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Vectra C power steering pump replacement
    By paulhea in forum General Motoring Chat
    Last Post: 17th September 2012, 13:59
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Power Steering Fluid Replacement.
    By Keif in forum Suspension, Wheels & Brakes
    Last Post: 5th June 2012, 20:20
