Thread: fuel filter cdti 150 .
    CHESHIRE
    Default fuel filter cdti 150 .
    guys want to change my fuel filter cdti sri 150, just had a look on the how2 guide nothing there, any tips on removing the canister part so i can get to filter inside cheers dave..
    Regular Member kev77's Avatar
    nottingham
    Yes mate it's easy did min the other day release the two pipes conected to the top then there should be a cable going to the bottom unclip that then you should find the unit will just push up and out the holder quite easy then I just placed the unit in a vise not to tight and used a 3 legged type oil filter remover to open it be carefull as it will be full of diesel then replace the rubber o ring and new filter and reverse the prosess takes about 20 mins remember to keep turning key in ignition to switch live without starting car a few times maby 6 or so you will hear the filter fill with fule then start as normal hope this helps
    CHESHIRE
    cheers kev yeah seems fairly straight forward , ill give it a bash at the weekend.
    ( daft question ) the 3 legged oil filter remover, is that correct name of the tool so i can go out and buy one..
    nottingham
    if you say you need an oil filter remover the one with 3 legs they will know what you mean and if you type 3 leg oil filter remover it will come up on ebay but there not really cheap i only used that because ive got one http://cgi.ebay.co.uk/Car-Oil-Filter...item4cee2a933a you could try pure man power but mine was really tight see if you can borrow one now you know what it looks like
    Sep 2009
    St Albans Herts
    Quote Originally Posted by kev77 View Post
    i did mine yesterday, there is a drain valve underneath for when you get holder off car, i put mine carefully in vice and undid ring by hand, first filter i bought was completely wrong, easy and straightforward to do
  1. Oil and fuel filter 1.9 cdti 150
    By chay6684 in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2012, 08:07
  2. fuel filter 1.9 CDTi
    By chrisgettings in forum Diesel Engine related
    Last Post: 30th January 2012, 14:33
  3. Where is fuel filter on 3.0 V6 cdti
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2011, 17:29
  4. cdti fuel filter
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 19:23
  5. Cdti Fuel Filter
    Last Post: 11th June 2008, 22:14
