Have just painted and fitted colour coded repeaters. Let me know your thoughts.
Before and after.
needs a clean though!!
Before and after.
like it, might give that one a go, did you remove them to paint them.
Nice mod!
I purchased a set of orange ones from ebay and sprayed them. Kept the clear ones incase of MOT faliure in the future.
Really easy to do. I am new to all of this moding stuff and have got the bug, BAD!!!!
looking good, i like to see c/c repeater's and just to let you know they are not an MOT failure, had mine done for ages now and never had any prob's....
Cheers. Altough that may depend on how easily you get carried away with a rattle tin and keep chucking paint on.
Can see the light though, so should be ok!!!!
how do you get access to remove them, is it through wheel lining.
NO!!!
Much easier. You can use a screw driver to pop them out.
But I found it easy enough to push on the pointy bit, push the repeater towards the back of the car and lift at the same time. Pops off in seconds.
even easier than i thought, cheers for the info.
Pleasure. Makes a change for me to be able to help someone out!!!
