Thread: Noise on start up
    Ayrshire
    Unhappy Noise on start up
    After replacing just about every sensor on this car due to other faults, i have now noticed (started today) a quick rattle when i started the car (about 3 secs) . so i turned engine off and never done it again. but looking into this it appears to be the chain from what i can see...whats involved in checking to see what may be causing this.
    Getting real P**sed off with this car
    Please help
    Regular Member benny's Avatar
    Feb 2006
    dudley
    i would be checking the tenstioner out ....they have been known to stick ...might be a idea to check the timing to see if it hasnt jumped ... .......
    Ayrshire
    Thanks benny, maybe thats the reason my car still runs like crap after replaing near enough the whole engine.
    I looked at autodata and is not overly clear, does the chain have markings corresponding to the cam?
    Do you need speacial tools for checking the tension and timing.
    BTW Cheers for the speedy reply
    Feb 2006
    dudley
    the chain has got marks on it that do line up with marks on the cam pulleys but it takes a few reveelutions (sp) to line em up ......best way to check is look at the bottom pulley it has a mark that lines up with a mark on the cover at about 11 oclock the the cam lobes on number 4 cylinder mine up with there inner mouting bolts ...so inlet cam points to 11 oclock and the exh points to the 1 oclock mark ....
    Ayrshire
    Thanks benny.
    Is it usual for a the yh engine to have this problem at 51,000 miles
    there is no apparent misfire. sounds a little lumpy and seems to struggle mid-high range speeds. I was going to get the egr blanking plates but now it appears i may need to check this first.
    What would the symptoms be if it jumped 1 tooth, (i dont know what the tolerances are like on this engine) presume if it jumps anymore, for example 2 or 3 would there be valve damage.
  1. Engine noise on start up
    By Brockettuk in forum Engine & Drivetrain
    Last Post: 24th August 2011, 17:06
  2. squeaking noise on start up?
    By darlodouth76 in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2010, 19:29
  3. start up noise
    By Howdey in forum Engine & Drivetrain
    Last Post: 9th June 2008, 20:45
  4. start up noise on 1.9 CDTI 150
    By gnomes in forum Engine & Drivetrain
    Last Post: 18th February 2008, 10:22
  5. Odd Noise On Start Up
    By sturgi in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2007, 20:55
