Thread: Oil leak
    WEST MIDLANDS
    Default Oil leak
    ihave got a 1.9tdi 150 05 reg ,got an oil leak on the bottom of the engain got my mate around tonigth he works for vauxhall, he thinks its 2 differant probs turbo seals on the one side and sump or rear main on the other so he is going to ring me with a price 2moz. Is this a big job ???? as it sounds priceie to me
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Usually only sump gasket that leaks, its not a gasket its sealer,,
    WEST MIDLANDS
    ok good or bad job on the sump ? but what about the turbo ?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i had a small leak on the bottom end oil seal picked up by the mech during a service, it stained the clutch plate so had new seal / clutch & modded dmf at the same time all under warranty, this was a costly job but as i wasn't paying i wasn't bothered tbh, then i was told about £1k worth of work
    Midlands Mod Shop - NFFC.
    WEST MIDLANDS
    great thats all i need, if it is costing me that sum of money then i will sell the car.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Two common leaks on the cdti are, 1 from the bellhousing area thats the usually the rear crank/gearbox seal (not that bad but gets blown about making it look worse), 2 oil leaking from the turbo area thats usually just the jubilee clips around the LARGE pipes want tightening, be carefull not to overtighten and bust the clip, the oil comes from the engine breather system sucking it back in via the air inlet (very common not to worry) its designed to do that.
    WEST MIDLANDS
    ok thats made me feel a bit better mate thanks
    now prob 2 on the car the front anti roll bar bushis on there way out to whats the best way to fix them top, bottom, side??? whats the cost of them ?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Not sure on price, depends on wether you fit vx, or after market, and im sure theres a how 2 for replacement.
    WEST MIDLANDS
    did look but can not find it.
    A few months after buying my car and a few days after the "first" service I noticed a small oil leak that was dripping on to the engine under tray, although it wasn't dropping oil on the ground
    The oil sump gasket had failed, processed under warranty and included new oil
    The job only took them slightly longer than a standard oil and filter change, but I had to wait three hours before they would release the car back to me to ensure the sealant had hardened and was not leaking
    The cost would have been about £120, but that is for a 3.0 V6 CDTI requiring 8 litres of oil
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Oil Leak
    By Tam80 in forum Engine & Drivetrain
    Last Post: 17th January 2011, 13:41
  3. Oil leak
    By Rich2.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 20:31
  4. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  5. 3.2 oil leak from?
    By megaderek in forum Engine & Drivetrain
    Last Post: 29th September 2009, 22:45
vectra c leak bottom end
vauxhall vectra 2005 1.9 oil leak www.vectra-c.com
vectra oil leak tray
vectra c oil leak
