Thread: aircon problems guys and gals any help
    slough
    Default aircon problems guys and gals any help
    i have a vectra c 150bhp 1.9cdti design 56 plate the air con switch lights up the fan goes faster but cool air comes out only had regased no different any help please
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Quote Originally Posted by hippo View Post
    so you put the air con on and cold air come out??
    or are you putting it on and want it on hot setting?
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Have you tried the recirculation button at the same time you put the aircon on ?
    This will stop any outside air coming in and should make your aircon colder.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Do you mean the air from the dash vents when set to aircon ON and full COLD is mildly cool on the back of your hand or rapidly becomes uncomfortably cold ?
    And by regased, do you mean you used a regas can or you got it checked and regassed by either Kwikfit or similar machine or aircon specialist ?
    slough
    [quote=hippo;1228923]i have a vectra c 150bhp 1.9cdti design 56 plate the air con switch lights up the fan goes faster and with the recirc on but only cool air comes out. had it regased there is a slight leak dont know where from. i need cold air from an air com system car no different any help please
    Oct 2009
    Sandwell
    [quote=hippo;1229165]
    so your air con dont give you cold air? didnt they check it when you had it regased? you say there is a slight leak, that might be your problem,
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Assuming you used the aircon regularly prior to this, the most common leak point is the condenser - it gets hit by all the muck, fluff, dust and custard from the road and commonly gets damaged.
    Easy enough to change yourself if you're handy with a set of tools and you have a Haynes book to hand.
  1. Hey guys and gals.
    By Chad! in forum Introduce yourself.
    Last Post: 8th August 2011, 20:35
  2. Hi guys - and gals!
    By CrisA in forum Introduce yourself.
    Last Post: 7th April 2010, 21:15
  3. nearly there guys and gals
    By dervdoc in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2007, 10:24
  4. Hi guys & gals
    By Toe in forum Introduce yourself.
    Last Post: 9th January 2006, 16:18
  5. By The Way, Guys And Gals.............
    By Mrs D in forum General Chat
    Last Post: 1st January 2006, 14:43
coolair vectra
