Results 1 to 10 of 19
Thread: Panel filter or enclosed induction kit help needed
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Exclamation Panel filter or enclosed induction kit help needed
    Hi all in a dilemma to get a k and n panel filter or a carbon enclosed induction kit with cold air feed so no heat soak I have a cdti 150 facelift Sri estate.
    What do I go for I want a good sound of the turbo but not massivly loud and also more performance but I don't know what to do
    Any help comments or advice and opinions welcome
    Been looking on bay and about 30quid for. A second hand carbon induction kit and same for a new k and n panel filter thanks guys hope to hear soon
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    I went for the enclosed induction kit... A Ramair from the bay, still using most of the stock snorkel at the moment, but am still trying it out.. It has a better sound already... more pick up, but as I am still testing it I can only say it is better than just using the airbox mod, and its the same price as the common KN panel filter which most say gives them little or no difference..
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Regular Member Marcosuk's Avatar
    Fife
    Quote Originally Posted by Caveman_nige View Post
    I concur....lol...
    kings lynn, norfolk
    thanks guys i see you have petrol cars
    has anyone fitted a closed induction kit on a cdti 150 and any one notice and improvments and also how loud does it sound on a diesel if you can get back asap thanks guys as i am going to buy one today if i get enough info from here cheers
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by winnie2457 View Post
    I have a Simota closed kit on my CDTi 150 and it sounds awesome. The turbo whistle is noticeably louder and the pickup is much smoother - but it has some great sounds when lifting off, more so when its cold.
    kings lynn, norfolk
    Hi dan I am deffo goin down the closed induction root now I am bidding on a few on the bay the question is in the 150cdti engine bay it looks tight for room. Especially as the maf points towards the rear could I attach the filter directly to the maf then take the cold air feed around 180degrees to the front intake or will I need an elbow to turn the filter around sorry if it sounds confusing lol.
    I am doing this on a tight budget so want to keep costs down to a minimum and hoping a can get away without buying silicone pipes or metal elbows and just use the filter and air feed
    Thanks hope to hear soon
    Lancashire
    Trim : XP1
    Mileage : 66000
    The Vec engine bay has loads of room on that side !! This is what the Simota kit is like...
    ....it follows the direction of the MAF then comes right back round to meet the OE intake (although this will be replaced with a direct intake soon).
    (sorry for the rubbish pic, its an old one with taken with a camera phone) !!
    kings lynn, norfolk
    The alloy pipe work I don't have all I have is the filter and a meter of black pipe that goes to the front grille do I need the alloy elbow or could I just put the filter onto the maf then take the pipe to the bumper with out any alloy or the bends you have if you know what I mean
    Lancashire
    Trim : XP1
    Mileage : 66000
    Is the length of pipe you have flexible..? If so then it can be bent to the angles you require.
    Similar to this...?
    http://cgi.ebay.co.uk/60mm-2-3-8-Neo...item439bda638f
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Thumbs up
    Dan....are you running with a tuning box or standard?............just a thought but i can't have my box on the higher settings as car seems to hold back.......was thinking this could be due to lack of cold air.........more air + box .....= more power..........
  1. k&n induction kit or panel filter!!!! or keep standard
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2012, 20:39
  2. k and n induction kit , or k and n panel filter which best
    By davedave in forum Petrol Engine related
    Last Post: 28th April 2012, 21:25
  3. Panel Filter or Induction Kit?
    By g33had in forum Tuning
    Last Post: 29th July 2010, 02:40
  4. Panel filter or induction kit???
    By goonturbo in forum Engine & Drivetrain
    Last Post: 27th February 2009, 00:12
vectra cdti 150 induction kit
Vectra C 1.9 cdti 150 metal turbo pipes
how to secure a inclosed induction kit
Panel filter
vectra c stainless filter to turbo
turbo not working when cold z20net www.vectra-c.com
vectra closed induction
