Thread: rear suspension problem
    Oct 2009
    sleaford
    Default rear suspension problem
    My 2.0T Vectra has developed a wallowy feel going round fastish corners, if theres a bump mid corner I can feel the car slipping sideways nearly loosing control. I have scoured the forum pages and tried the old moving the wheel side to side test and there is movement on the rear left, is this an upper control arm issue? and also I jacked the car up on both sides and removed the wheel, and on the right hand side I noticed there was fresh oil eminating from the damper surely not a good sign, if I change these parts is it worth changing upper control arm on both sides and the damper on both sides and maybe while im at it the springs as well.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Well, the damper needs changing away and needs done. You could do that and see if thats the problem before spending money on changing them all.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    :whs
    Jun 2009
    South Coast
    Regular Member HB39AA's Avatar
    Oct 2006
    GERMANY
    Quote Originally Posted by philjensam View Post
    over the last couple of weeks i have had the same handling problem as you, and like you one of my rear dampers has gone. I have got a pair of bilstein B6 going on tomorrow and fingers crossed that will cure it.
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The movement in the rear left is almost definately a shot upper control arm. The leaky damper will not be helping either.
  1. Front suspension problem
    By chrisvectra in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2012, 00:17
  2. Suspension problem
    By Fishmichael in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2011, 21:29
  3. Suspension problem?
    By tony-1977 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2010, 18:15
  4. possible suspension problem?
    By Big Knox in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 22:22
  5. My car has a rear suspension problem
    By ANDY W in forum Handling & Braking
    Last Post: 22nd June 2009, 17:34
