Thread: ctdi 150 po400
    Derbys
    Default ctdi 150 po400
    A friend of mine has a 2005 55 vectra C sri cdti 150, It had very poor power below 3000 rpm, the inlet manifold has just been replaced due the rod been worn out, power is now alot better but somtimes is still alittle flat, the egr has been removed and cleaned but the em light still keeps coming on with po400 EGR Insuficiant flow
    Any ideas
    Thanks Gav
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    He may have a faulty EGR valve,just because he cleaned it doesn't mean it will work
    Irmscher Insignia CDTI 130
    West
    check vac tubes & connectors & or sticking egr
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    cleaning the EGR to last has to be done properly! even a thorough clean can miss vital parts, (try to post pic, you cannot see this part unless you operate the spring during cleaning,) its the shaft running through the shroud thats the pig!, After cleaning make sure the boost sensor and throttle body are clean check all hoses and vacum pipes and a egr fiat semi blanking gasket is a worth while buy!. Also its a must to strip the elec solenoid and clean it, lubricate it without grease.
    Derbys
    Thanks very much for the replys
    Where can a semi blanking gasket be obtained from?
    Thanks Gav
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    a fiat dealer, but i wouldnt do this without going through the points ive mentioned!. pitty you werent closer i would have given it the once over for you.
    http://www.vectra-c.com/forum/showthread.php?t=106837
    you will require the square one for the 150
  1. Where's the HOW 2 for cleaning EGR Valve CTDi [150] - Can see it
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2012, 14:17
  2. Rob12's SRi 3.0v6 Ctdi estate
    By Rob12 in forum Vehicle Diaries
    Last Post: 21st June 2012, 11:57
  3. 3.0 ctdi or 1.9 (150) ctdi
    By kirky2k4 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2010, 11:14
  4. 2006 Signum PO400 EGR Problem
    By b0z83 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2009, 15:40
