Thread: 2.2 direct spanner light
    Huddersfield
    Default 2.2 direct spanner light
    Can anyone help?
    2.2 direct, spanner light came on this morning. car drives normal and idles fine. 50k on engine.
    what should i check first?
    anything i can do to read the coded off?
    pls help someone
    Regular Member steve.s's Avatar
    Mar 2007
    spalding, linc's
    that happend to me on friday, when going to dealers for recal, fule regulator, they plug into ecu and it said it was faulty, ecu might be knackerd but wont know properly until tomorrow, starting price £400 for ecu.
    Oct 2006
    Wellingborough
    as steve says, get to the dealer and ask about fuel pressure regulator recall.
    Huddersfield
    is it worth getting the code read first? if its not the reg or owt I dont want the dealer to spank me
    will the car stop driving at some point if it is the reg?
    Regular Member tightlines's Avatar
    Apr 2009
    at home
    sorry for the hijack.
    i had the same problem when i went out earlier,
    ive got the spanner light and the light that looks like the engine block.
    its not showing any fault codes, when i tried, would like to know if its something serious with both lights on.
    Huddersfield
    tightlines, how did u check for codes?
    Apr 2009
    at home
    Quote Originally Posted by DaveB View Post
    off the how 2 but not really sure if ive done it right, think its a trip to vx tomorrow
    Oct 2006
    Wellingborough
    They wont charge you for checking if your car is covered by the recall. if it is covered, they'll replace the regulator FOC and (hopefully) your issue is solved.
    elland
    had he same prob & it turned out to be the coil pack. Does the car run in "crawl mode" or run ok all of the time?
    Huddersfield
    Car runs OK with the light on/off.
    Did 15 miles in it last night, - no light.
    gf has done another 20 miles in it today, again no light.
    I rang vaux in Huddersfield and the unhelpful service man said that there is NO recall for any Signums at all, and if I want anything checking it will cost at least £75
    Think we'll just keep driving it until it stops; easier to find the faul that way.
    I did try reading the codes using the pedal method, but nothing came up - but then if the management light isn't actually coming on, then I guess it wouldnt?
  1. Vectra 2.2 Direct Auto Car and Spanner light
    By m2yuout in forum Engine & Drivetrain
    Last Post: 11th February 2013, 20:43
  2. 2.2 direct spanner light help!!!!!!!
    By pj2511 in forum Engine & Drivetrain
    Last Post: 7th August 2012, 21:19
  3. 2.2 Direct spanner light. Help!!
    By jrh1 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd December 2011, 22:14
  4. 2.2 Direct,flat spot then spanner light
    By johnmac in forum Engine & Drivetrain
    Last Post: 12th July 2009, 14:08
  5. 2.2 Direct Spanner light then dies....help please
    By simp_2.2sri in forum Vectra C / Signum Troubleshooting
    Last Post: 14th October 2008, 09:41
