Results 1 to 10 of 13
Thread: Hypothetically, could this be done?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Hypothetically, could this be done?
    If my car were to have a major failure, say the fuel pump went or the engine went into melt down, could I fit another diesel engine, say the 3.0v6 into my car?
    Now before people start saying "can bus this" and "can bus that" and "it can't be done", if you were to buy a badly written off vec (rolled and roof is crushed to bits) could you swap all of the electronics from it with the engine into another car?
    The only thing that would be different as far as the bcm's are concerned is that they are in a different shell but they aren't that clever (or are they )
    It could work out cheaper to buy a Cat B vec than to repair a badly damaged engine
    Just a theory guys
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Just a theory guys
    Yeah, as long as money isnt an issue its easy, though I dont see this costing too much itself but how much would an engine from a bust car cost?
    Gazza4
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    IN THEORY....
    ... Yes, you could take the engine, gearbox, all relevent ECUs, cables and connectors from one diesel and refit them in another. Apart from the shear time and effort required, the overriding 'stopper' would have to be cost - It would be far cheaper to just buy a complete alternate vehicle rather than try to do all that to your existing one (assuming it had died).
    Theory... Myth Confirmed
    Practice...Myth Implausible through cost.
    You'd probably need every single bit of electronics to avoid too much tech2 stuff, but yeahin theory there's no issues with it I'd have thought...
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Well you can buy cars that are for breaking only for around a grand (yes that cheap)
    As long as it's a good runner then the only thing it should cost is the cost of the car. The rest of it would just be time and I have loads spare
    If you were lucky enough you may get a facelift bodied car that the front could be swapped from (assuming its not wrecked of course)
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by Penfold101 View Post
    But certain things like airbags etc can be fitted from a scrap car into another one so there is no reason the old ones couldn't be used.
    I know that things such as speedo's and door modules etc would all need to come from the doner car but parts such as window motors and switches would surely be compatable
    Yeah, definintely - just all the modules, ECU's and immobiliser etc that would need taking across. And if you found a high spec'd one with better looms who knows what else you could add...
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Stock parts would just be a straight swap.... engine specific parts and those appropriate to the engine (larger brakes, different radiator, etc) would theoretically come from the donor veh.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I only read the first sentence...
    NO NO NO NO NO!!!!!!!!!!!!!!!!!!!!!!!!! lol
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Well lol, I was just thinking to myself there, if this could work, I could have a 53 plate Vectra SRi 2.8t
