Results 1 to 10 of 14
Thread: Traction control query
    Regular Member kamar's Avatar
    bradford
    Default Traction control query
    hi guys just wanted 2 know ive got a 2006 vec cdti 150 is traction control an option or hasnt my car got it. when the wheels spin there is no light flashing on the dash, an neither does it cut the power out like my tdi 130 bora did..i thought all face lifts had it may be im rong...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by kamar View Post
    If you open the engine there is the ABS unit that sits behind the battery compartment, and im sure it tells you on that. Tbh I though TC was standard on all CDTI's up until 2007, but im no sure.
    Gazza4
    bradford
    iyl check i thought thought all cdti's had it standard...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    So did I but found out apparently vx went on another cost cutting spree and removed it from the last of the CDTI's.
    Gazza4
    bradford
    lol no wuries not like i drive it as an f1 car.....
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Only the V6 models on facelift cars had TC as standard. You could have TC with the ESP as an optional extra on the facelifts as I did. It would be very unlikely for you to have TC and if you have never seen that light come I'd say you don't have TC.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    You can have mine if you like it does s0d all anyway - from what I can gather ABS on the Vectra tends to be either too intrusive or totally useless as mine is. It reacts a bit if just one wheel loses grip but both wheels can spin away merrily with little of no effect. I've had it checked by Vx who say it's working correctly
    The Traction Control in the Vectra C is calibrated to a higher threshold than it was on the Vectra B
    I found it very useful on the Vectra B, as you could plant your foot, the Traction Control would control the revs and prevent ANY wheel spin (well I did measure it once and it was less than one tenth of a revolution)
    In the Vectra C you can easily spin the front wheels, but eventually the Traction Control does intervene, but I am sure by that time the wheel has spun through at least one third of a revolution
    According to my brochure for a 2005 Vectra, Traction Control is standard except on the 1.8
    ESP is optional, fitted as standard on V6 models
    If ESP is fitted on a 1.8 then it also has ESP
    Full Member Big Sig's Avatar
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The TC is useless. My V6 spins the tires in 2nd and torquesteers like a mad cow. lol
  1. Traction control light,quick query
    By mike. in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2012, 15:15
  2. Traction control light query
    By samarkh in forum Suspension, Wheels & Brakes
    Last Post: 27th January 2012, 21:05
  3. my abs/traction light but locknut query
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 19th December 2009, 01:08
  4. does my car have traction control?????
    By dannydm1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2009, 10:38
  5. Traction Control
    By Hs2300 in forum Engine & Drivetrain
    Last Post: 6th November 2008, 00:15
vectra b v6 traction control
