Results 1 to 10 of 11
Thread: The DMF is calling me,
    Regular Member DavieVectd120's Avatar
    Washington
    Default The DMF is calling me,
    Yep its rattling like a heroin addict going cold turkey.
    How much should I be looking at paying for the parts?? anyone know, also do any of you good people have any idea what I should be paying for the labour, I know its going to be pricey but its gotta be done.
    Regular Member george1987's Avatar
    Nov 2009
    Plymouth/Southampton
    i think there are some available on ebay, but you are looking at £400 plus and then the labour charge on top. Bear in mind, some other threads have said that if you have to change the DMF, then it is cost effective to change the clutch too if haven't already (depending on mileage and age etc). Hope this helps
    Washington
    Quote Originally Posted by george1987 View Post
    Thanks for the pointer George.
    Washington
    the mileage is 73000
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    TBH if the car has done any more than 20k on the original clutch, change it.
    No point in fitting a flywheel and then having to pay extra labour to change the clutch later on.
    Washington
    I am going to get some quotes tomorrow, the missus is blowing a gasket here, just had timing belt and water pump done.
    Its going to be allot more costly if the flywheel splinters though. The ladies dont understand these things. The remap will have to wait now
    caistor
    i have the same problem mate mine in the garage at the min cos it went completely needs g/box dmf and clutch and the mechanics also think that the egr valve has gone
    preston
    My dmf started rattling for 4 months before I changed it myself, parts cost £500 there or thereabouts, you will need dmf and a clutch kit i.e. friction plate, pressure plate and thrust bearing plus some fresh gearbox oil and clutch fluid. On top of that you have fitting cost. My car had done around 100k and the clutch was hardly worn but i did not want to risk having to do the job again.
    All this because a plastic ring , yes plastic ring gives way, its a p****r I can tell you and is seen in one of my previous threads with pictures. The manufacturers of these flywheels need to sort this problem fast if not done so already!!!!
    Washington
    Quote Originally Posted by aledjones_lex View Post
    Gutter mate,
    On a positive note though, enjoy the car when its fixed! you will be
    Washington
    Quote Originally Posted by bygumlad View Post
    Thanks for the advice mate, is that all it is! a ****** plastic ring!
  1. Gsi ,vx calling
    By noudder72 in forum Engine & Drivetrain
    Last Post: 24th April 2011, 19:07
  2. Calling Aja
    By andy.l in forum General Chat
    Last Post: 14th September 2007, 12:41
  3. Scotland Calling
    By vectrahunter in forum Introduce yourself.
    Last Post: 27th May 2007, 19:53
  4. Calling AF
    By marichrd in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2006, 21:50
  5. Calling ALD.....
    By Big Davie in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2006, 14:35
