Thread: Brakes not holding pressure...
    Northampton, UK
    Default Brakes not holding pressure...
    Following on from this thread - http://www.vectra-c.com/forum/showthread.php?t=107610
    The garage the guy took the brakes too apparently say the brakes don't hold pressure.
    This is the message from the guy who bought them...
    hi mate thanks for getting back to me, its a independant garage near me, he does all my work, he bleeded the system many times, he has told me that the calipers arent holding the pressure, when you apply the brake there is nothing then press it a a 2nd time there is a bit, then the 3rd time there is a bit more, but if you hold it down on the 3rd time all the pressure goes and you cant stop the car, only the rear pads work.
    I then went to penfolds vauxhall garage and they told me that my car CAN take the bigger brakes, and they said my only choice was to get the brakes stripped down to see whats wrong. Im also sure the mechanic i took them to knows what he is doing cause he put my old brakes on and they work fine, anything else you can think of?
    Anything guys??
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    sounds like tryin to pull the wool over to me maybe a hole/split in a pipe somewhere
    If they are not holding and not leaking then it must be his brake servo. Maybe his fitter pushed the pistons back without opening the bleed nipple and has forced the seals over in the servo.
    Northampton, UK
    But wouldn't that affect his normal brakes?
    My garage...? WTF...?
    Anyway - sounds like something in the master cylinder or servo mate, as if there was anything wrong with the calipers they'd simply be leaking - there's nowhere else for the fluid to actually go after it leaves the ABS unit...
    all the calipers do is capture the fluid and hold pressure within them. Only place for the pressure to go is back into the system via a dodgy master cylinder or servo or through the seals of the caliper and onto the floor.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I've just fitted new disks and pads and it did it on my car, does it every time I change pads. Multiple pumping of the pedal and handbrake, turning the ignition on and off always sorts it (I presume the ignition bit does something to the Vac). Is the guy aware of Diesel creep?What the guy has described is exactly what happens to mine. I know we can get round it but VX advise reverse bleeding of the brakes, so you put the fluid through the caliper and push it out the reservoir, he may just have a temperamental system that need this?
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. Holding back
    By obews in forum Engine & Drivetrain
    Last Post: 29th December 2012, 10:22
  3. upgraded to 314mm brakes, now no pressure.
    By Mark_k in forum Suspension, Wheels & Brakes
    Last Post: 29th November 2011, 21:42
  4. Holding gears
    By app in forum Engine & Drivetrain
    Last Post: 3rd June 2008, 10:46
  5. Just holding my hands up
    By Ben H in forum Billing 2006 8/9th July
    Last Post: 2nd July 2006, 14:42
