Thread: Heating problem
    Crawley
    Exclamation Heating problem
    I have a vectra cdti 1.9 2006 reg my question is about the engine heating Needle it dosnt stop it goes up to 93'c and the after a while down to 85'C it does it all the time can sombody tell me why ! And it uses mor diesel when it's on 93'c can sombody explaine and help me thnx
    When moving or when stopped? if its when stopped its normal as thats about when the fans cut in.
    preston
    Its just the thermostat opening and closing to me.
    Crawley
    Yeah that's the the thing even if I drive it does it.
    preston
    The needle on mine does go up and down but is relevant to driving conditions, i.e. when accelerating on motorways its starts to rise then when coasting it will drop. Is this what is happening in your case or is there no pattern to it, seems an odd one if it is just spontaneous, may be a faulty temp sender unit.
    Aug 2009
    Havant
    my 1.9 never goes over 80.... rarely actually reaches 60...
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by bappy View Post
    Your thermostat has stuck in the open position...however, if it NEVER goes over 80, even when stuck in traffic, then I would query the temp sender.
    Regarding intermittent high and then low readings,
    This could be a lack of coolant, going round the engine, so when flow is reduced the engine warms up, and when the limited amount of water goes back round it's cycle past the sender, it cools suddenly, and then the cycle repeats...
    Otherwords check your coolant level, top up if necessary and remedy any potential leaks before you over-heat and warp your cylinder head.
    Had this a long time ago in my cavalier
    Aug 2009
    Havant
    interesting.. cheers. fluid level is where it should be. sometimes does go over 80 but only in traffic uphill for ages in warm weather, then it doesnt go over 90. is this bad for the engine? should i replace my thermostat?
    ta.
  1. heating problem
    By keithv1 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th January 2013, 17:46
  2. Heating and blower problem?
    By shaine415 in forum Engine & Drivetrain
    Last Post: 26th February 2012, 17:07
  3. Heating Problem - Vec C 2.0 DTI
    By bidey89 in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2010, 12:38
  4. Problem with heating...
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2010, 07:56
  5. 2.0 dti heating problem
    By jmacp in forum Bodywork & Interior
    Last Post: 23rd November 2008, 13:42
vectra c engine heat problem
