Thread: Overheating
    Coventry
    Default Overheating
    Hiya all,
    The Car: Vectra elegance 1.8 saloon - 2003
    Problem history:
    Car constantly ran cold - Thermostate changed
    Leaking radiator - Changed.
    Heater blowers blowing cold air - Thought this was thermostate (but still runs cold?)
    Latest problem:
    Very strange overheating. You can drive for a while and car runs ok but the temperature fluctuates between 85C and 100C. Then out of the blue it increases to over 100C into red (shut down engine when this happens - temp warning light flashes).
    I have been told that when the radiator was changed they have to bleed the system which on these is a pain in the bum. But I am not convinced that this is a bleeding issue as the heater blows cold air and has done for 12 months now, but I have changed the obviouse things like thermostate.
    Could a blockage in the heater matrix cause the cars temperature to behave this way? The car is not loosing any water (well since I changed the raiator anyway). I have checked the water pipe into the radiator (and its hot) and coming out is cold (or almost cold). Or is this a water pump issue?
    Any advice?
    Nov 2012
    london
    Vehicle : Vectra c facelift flame red
    Quote Originally Posted by Steve1974 View Post
    Hiya all,
    Problem history:
    Latest problem:
    Any advice?
    Any replies to this? I am having this problem on 1.9cdti
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    sounds like water pump to me
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    If it seizes it can take the timing belt out! Drive at own risk....
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    (do not drive car turn off engine before damage )
    repeat
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 139000
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Naw, the system is self bleeding.
    Quote Originally Posted by vectra ste View Post
    Take the cap off the expansion tank and start the car. Look into the expansion tank and you should see water returning to the header at the 6 oclock position, if you dont then yes id suggest the water pump has failed.
    Heres 2 videos from my 1.8, 1st one from cold and the second one from when it goes off the cold start valve.
  1. Cdti 150 overheating
    By WHOOSH05 in forum Engine & Drivetrain
    Last Post: 29th August 2011, 11:43
  2. Overheating or not ???
    By Grahamy in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 19:22
  3. overheating
    By jonesey42 in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:24
  4. overheating/no hot air!?
    By P-Mutton2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2009, 11:54
  5. Car Overheating !!!
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 17:56
56 vectra 1.9 cdti overheating
