Thread: Painting Question...
    Northampton, UK
    Default Painting Question...
    At the minute I'm practicing on a spare bumper I have lying around before I have a go at mine...
    But I've hit a problem...
    I've sanded it down, primed it, then painted it, then lacquered it...
    Problem is, it's really dull... No shine... The paints smooth, but really matt
    I've never tried anything like this before. LOL
    Do I have to wait 24 hours and then polish up the Lacquer or something?
    Cambridgeshire
    What sort of paint are you using?
    It may need a good doing over with some polish but not too sure. I'm looking to learn how to start painting too
    Northampton, UK
    Its VX spray paint, I bought a couple of cans to have a go... I've got the Grey Primer and Clear lacquer.
    So just a quick polish when dry you think?
    Regular Member badback's Avatar
    Runcorn
    I would think it needs to be in a warm enviroment when spraying and drying.
    Northampton, UK
    Have you been outside today LOL. I'm thinking thats the problem, I'm maybe spraying it on to hot a surface???
    Oct 2007
    Shropshire
    It is very hard to get the laquer clear on some colours. Silver and black are the worst you sort of see straight thought the laquer, its very hard to spray...
    WGAF#5
    did you remember to flat the painted area back down prior to lacquering ??
    Aug 2009
    Havant
    rub down painted area with 800 grade wet prior to laquering then give at least 3 or 4 coats of laquer to make sure its really thick. if it's dull you're doing it right - it means you're building up lots of little layers rather than going nuts and pouring the laquer on - this will nearly always create nasty runs in the paint. when you're happy you have enough coats of laquer rub it back with 1500 grade wet prior to rubbing with tcut scratch remover or similar. unless you've managed to spray a layer of damp into your laquer you'll get a beautiful finnish
    always use enamel laquer on the real thing as opposed to regular stuff - its much harder wearing and is more resistant to solvents.
  1. a bit of help on painting plz
    By veccy c in forum Styling
    Last Post: 6th March 2012, 10:45
  2. House Painting & Decorating - Corner/Edge Painting advice
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 14th January 2011, 17:45
  3. Painting...
    By mickyblueyees in forum Styling
    Last Post: 28th May 2010, 21:49
  4. Bumper painting question. waterbased or 2pac?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2009, 05:12
  5. Damaged bodywork painting question
    Last Post: 21st May 2007, 21:04
