Thread: Computer display showing strange temperatures
    Regular Member Nato's Avatar
    Risca, South Wales
    Default Computer display showing strange temperatures
    Hi all, finally got hold of an 04 plate Vectra SRi 2.2 yesterday, and it's been running great so far (touch wood). Just one small issue though - the computer display is showing temperatures in the high 30s-low 40s. Now I know it's getting warmer out, but it's nowhere near that hot!! I also appear to have no cold air - just hot hot air blowing through my vents, even with my aircon on. I'm guessing it's a combination of a discharged aircon unit and a stuck solenoid behind the heater control unit for the hot air, but what about the temperature display?
    Like I say, just little niggles, but I'd like my new pride and joy to be right!
    Mileage : 000
    Might be the sensor by the front bumper. You can get them off Ebay quite cheap.
    May 2008
    Doncaster
    If you bought it from a garage mate are you not able to take it back and get the bits you've noticed fixed?
    If it was private then I guess there's not much you can do really.
    The outside temperature probe, I believe, is stuck on the front bumper near the bottom so if you try cleaning the connector a bit it might just be a faulty connection, failing that it may be best replacing it if that doesn't work.
    I think you're on the right track with the heat problem inside the car but someone better at that area will respond soon I'm sure!
    Risca, South Wales
    Quote Originally Posted by nickabbott2008 View Post
    It was a private sale fella. To be honest I had a pretty good price on it so not too bothered about spending a little money on it. Just be nice to have them sorted with it getting warmer.
    May 2008
    Doncaster
    Quote Originally Posted by Nato View Post
    Lol you're not wrong there! Had the A/C on the other day for the first time in 6 months! Must have been parked in the sun all day because it was hot!
    Even warmer today but not been in the car yet!
    Regular Member kamar's Avatar
    bradford
    i had a vecy 2.2 dti sri on a 53 when i got it in the summer back in 07 it use to show same tempreture 30-40+ i left it in winter is showed the normal cold temp as it came to spring it was all perfect... but what i noticed was the temp was in farenheight it displayd F not C if u read the manual theres some way to change it...
    Risca, South Wales
    Mine's parked right in the sun! Looks awesome with the sun reflecting off the black paint, but by god it's gonna be hot if I have to get into it!
    Risca, South Wales
    Well, no regas needed for the aircon - it works fine!! Cleaned and refitted the internals of the control unit and all seems to be ok with it. Going to be refitting the control unit for the blowers on Thursday, so fingers crossed!
  1. computer display
    By Pie Sharp in forum Electrical & ICE (including SatNav)
    Last Post: 5th April 2009, 14:29
  2. Computer showing crazy MPG after remap!!
    By CNC in forum Engine & Drivetrain
    Last Post: 30th September 2008, 20:13
  3. Driver side door shut but showing open on display
    By eclipse in forum Bodywork & Interior
    Last Post: 13th August 2008, 11:14
  4. Computer display
    By stubopvectra in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2008, 01:10
