Results 1 to 3 of 3
Thread: Brake parts
    Liverpool
    Default Brake parts
    hi guys had my mot this morning and passed fine. The tester said i will need front brake discs and pads they gave me a price of £135 fitted.
    Does anybody know what size discs are on the 05 plate 1.8 sri. had a look on ebay but need part no.
    thanks
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    The size of mine was stamped on the caliper itself if you look closely. I would imange their 285mm. Did mine myself, fairly easy but the caliper bolts are blooming tight so you need a big bar. Also need relevant torx socket, loctite, 7mm allen key and a little torx for the disc itself.
    http://www.vectra-c.com/forum/showthread.php?t=42093
    found this
    Brakes
    Front ventilated disc brakes:
    1.8i 16v/2.0DTi 16v/2.2DTi 16v/2.2i 16v –
    285mm diameter.
    3.2i V6 24v – 302mm diameter.
    Rear disc brakes:
    278mm diameter.
    3.2i V6 24v – 292mm diameter.
    Liverpool
    thanks john just ordered a set from archiemoss on ebay £70.50 with free postage so will get them done in the week. thanks for your help mate
  2. Euro Car Parts - which brake pads, come up with 4 options!!!
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 14th November 2011, 21:41
  3. Cant find brake upgrade parts.
    By muad_dib77 in forum Handling & Braking
    Last Post: 11th March 2011, 19:33
  4. Brake Parts
    By John LE in forum Part Numbers
    Last Post: 15th March 2010, 02:02
