Thread: 314mm Caliper Details, Numbers or Distinctive Marks?
    May 2008
    Doncaster
    Default 314mm Caliper Details, Numbers or Distinctive Marks?
    Hi,
    This thread would have been perfect but the answer was never posted! I need all VX part numbers:
    http://www.vectra-c.com/forum/showth...caliper+number
    But the reason for asking is I've got some 314mm calipers with everything including the hub assembly! But I need to know they're actually 314mm not 302mm as they were from a breaking V6 on ebay.
    Cheers!
    Nick
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    They are very distinctive with how they look, and the pad retaining clip etc.
    The pad retaining clip on the front is square and very meaty, not jsut a piece of wrie...
    Blantyre
    SHE !!!
    Quote Originally Posted by spennny View Post
    SHE !!!
    Whoops - finger slipped...
    This is what the 314's look like mate - 302's are totally different...
    May 2008
    Doncaster
    Quote Originally Posted by Penfold101 View Post
    Cheers for the help guys, will go out and take a look now and probably take a picture to compare!
    Just got cleaned up too!
    May 2008
    Doncaster
    Also, if the picture on this page of the 302's to the 314's is right then mine look to definitely be the 314's!
    http://www.vectra-c.com/forum/showth...alipers&page=2
    Why do they look so much bigger if there's only meant to be 1.2cm difference?
    Or am I thinking of it wrong? Like when you measure a TV diagonal instead of horizontal etc.
    Cheers,
    Nick
    Quote Originally Posted by nickabbott2008 View Post
    Nope, it's simply the disc diameter mate. The reason there's so much difference? God knows...
  1. 314mm caliper clips
    By Caveman_nige in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2015, 17:45
  2. 314mm Brake Caliper code..?
    By dv8 in forum Suspension, Wheels & Brakes
    Last Post: 25th August 2008, 13:04
