Results 1 to 3 of 3
Thread: Relay Question
    Sunerland
    confused Relay Question
    I have to fit a relay to my parking sencors, because sometimes they work and sometimes they dont. i have bought ,
    MULTI-FUNCTION RELAY 4 PIN 12 VOLT 30 AMP
    with numbers :-
    30
    85
    86
    87
    i know 30 = permenent live
    85 is earth
    which leaves
    86 ?
    87 ?
    I would like to know which number i put the wire which i would normally put on to my reverse light wire, then that would only leave me with one wire left which then would be live out.
    If i tried to guess these two possitions would i short out the relay if i got it wrong ??
    Thank you guys for your reply,
    regards,
    Steve.
    cambs
    here you are m8
    you will get what the pins are for
    http://www.accessconnect.com/fog_dri...hts_wiring.htm
    Sunerland
    Your a STAR mate thank you.
    Regards,
    Steve.
  1. Can you name that Relay?
    By Journeyman in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2016, 17:54
  2. Indicator Relay question?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2012, 16:14
  3. Relay question
    By JagRigger in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2012, 14:18
  4. A little help with the R7 relay
    By mofozo in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2011, 20:03
  5. Which relay is which?
    By JamesG in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2007, 19:18
