Thread: Water leaking from front washer bottle
    Regular Member the-converter's Avatar
    Australia
    Question Water leaking from front washer bottle
    Does anyone know how to fix / stop water leaking from the front washer bottle near the connection of washer pump?
    You need to check a few things.
    Has the bottle got a split / crack in it?
    Is the washer pump pushed right into the rubber grommet filter?
    Is the rubber grommet filter split?
    Are any of the water pipes split or not connected properly?
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    I had same problem you need to push the pump home correctly. Use a reasonable amount of pressure.
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    If the rubber has gone hard put it in some warm water and work it between your fingers!!then re assemble
    Australia
    Default Resolved
    Thanks mate.
    Fixed the dripping.
    One of the pipe was disconnected from the pump.
  1. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  2. water bottle for rear window washer
    By hovis007 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 12:38
  3. Leaking power steering bottle?
    By DKM in forum Suspension, Wheels & Brakes
    Last Post: 19th June 2009, 19:49
  4. washer bottle
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2009, 18:08
