Likes Likes:  3
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
Thread: Retro Fitting Scroller Wheel controls
  1. #21
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    This is the scroller wheel connector plug.
  2. #22
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    This is a VERY old thread, but I have only just finished the work today.
    For information this is for a pre-facelift full can system..
    CD70 and CID . The pin numbers and back plate are the same for a half can wheel though, so I could have got one from an earlier car had I thought about it..
    The pin out for the connector (as it goes into the CIM)
    are
    Pin 1 = Brown/white - right switch and horn power feed
    Pin 2= Brown - Ground for switches and the horn
    Pin 3 = Blue/Red - left switch power feed
    Pin 4 = Grey - illumination
    Well I finally pulled my finger out and fitted my scroller controls.
    The existing back plate had no wires nor pins to attach my scroller plugs to.
    So this is what I did..
    Disconnected the Battery
    Waited 5 minutes to allow any capacitors to discharge.
    I then pulled the steering wheel as far from the dash panel as it would slide to allow access with a screwdriver from behind
    A No 2 Philips screwdriver is fed into two small holes and "wiggled about" to release the retaining lugs inside
    The airbag just pulls off..
    Disconect the airbag wires (1 x purple and 1 x yellow connectors )
    I had to remove a pair of spoke blanks from the wheel..
    These are held on by a single Torx screw each - T25 I think...
    Then carefully, but firmly - pull them from the rubber spokes.
    Then you need to undo 3 x Torx bolts to allow removal of a metal backing plate.
    and then behind this is the contact plate.. remove this after removing the connector in the the upper left of the steering wheel boss.
    On my contact plate, there were only two wires..
    1 x brown = Horn ground wire
    1 x brown/white = Horn power feed.
    I needed to add two more wires..
    1 x grey = illumination for the switches
    1 x blue/red = power feed for the left switch unit.
    Also there were no pins in the little three pin sockets... so I also had to solder these in place...
    I got these from spare connectors (male plug obviously).
    I temporarily fitted the blue connectors for the scrollers, and used these to hold my pins in place during soldering.
    On completion, the whole lot was fitted to the steering wheel, complete with the scroller controls.
    The illumination of the controls will work in conjunction with the light switch... but the scrollers will not as they were not programmed in.
    The left scrollers do nothing, but the right ones will sound the horn..
    (The right controls share the earth and power feed with the horn.)
    It is now necessary to program the display and CIM unit
    Display - set controls as present
    CIM - Set controls to Scrollers.
    The result is working controls....
    The images below show the contact plate in it's varying stages..
    1) As it came off the car
    2) The blue/red and grey wires soldered onto the back plate
    3) The pins soldered onto the contact plate.
  3. #23
    Regular Member no1baggiesfan's Avatar
    Jan 2008
    Newcastle
    Vehicle : 1.8 VVT SRi
    Have just done this mod, soldered the 6 pins in, added the two wires, got the new horn buttons
    Took it to stealers this morning and the tech2 guy had to reset my cim to add the commands for the scrollers as they were "locked".
    I now have 100% working scrollies WHOOOOOP, thank you Robsey.
  4. #24
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    No problems, glad to be of help.
    This is a very simple programming job...
    It is not a matter of resetting or locking the CIM, but just a matter of re-programming the "Variance Configuration Settings".
    Takes longer to crank up the programmer, than the actual programming operation itself
  5. #25
    Jan 2008
    Newcastle
    Im not sure what was locked, but I watched the technician using the tech2, every time he told the CIM that the controllers were present it flashed up "parameter locked" or something very similar, but, he reset the CIM and tried again and it worked lol, just have to back now and get my spare key recoded.
    Next up, decent suspension and shocks
    Then its a remap.
    PS. yes, it takes ages to tech2 anything lol, we must have been dicking around for 30 mins lol and the ****** horn kept sounding everytime he finished setting a parameter.
  6. #26
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    I used opcom.
    3 minutes to crank up the lap-top
    1 minute to program
    30 second wait to allow the modules etc to "settle"
    Job done
  7. #27
    Jan 2008
    Newcastle
    the tech who did it says he owns an astra gsi, he uses something called kwp or kwt and opcom to mess with his car.
    Can opcom program steering controls too ?? I didnt know that lol, I have a friend who has/had one, not sure if it was the proper one or not, he just said he had one, that would have saved me a long time ago lol.
  8. #28
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    Yup Op-com will do this too.
    I use Op-Com for both CAN and KWP vehicles.
    By the way KWP is for half CAN vehicles and earlier, where some analogue signals are used in the diagnostics process.
    Astra-G before 2003, Omega-B, Zafira-A, Vectra-B and Corsa-C are all KWP vehicles
  9. #29
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Hello Robsey, thanks for sharing.
    Could you please list the steps to get to the variance configuration settings for both modules with the Op-Com ?
    I think I have an old software ; I heard that there's now a stable version for Win7 that may have more options (I'll still use it under XP, I'll check a friend's topic who gave the correct working version), so maybe I don' t have the relevant options working, or maybe I just can't find them...
    And another thing : I know, because it happened to some people I read from on forums, that sometimes a connector to the CIM can have faulty contacts and needs repair and/or cleaning.
    I can't access my CIM with my Op-Com, though all related stuff is working normally (stalks, wheel buttons, and so on).
    Maybe you know where I have to look to find the connector that's known for that ?
    Or maybe my CIM has a problem, but how can all be working, then ? Or maybe just the CAN communication... Anyway, the Op-Com reports errors for several modules (BCM, UEC, etc.) attempting to communicate with the CIM and not founding it.
  10. #30
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    Wow - "Holy thread resurrection Batman.!!"..
    The cheap and cheerful opcoms that people discuss are all still pegged back to a February 2010 version of software.
    Official Opcom / Vauxcoms are currently upto June 2012 software.
    The official software will not work safely with the cheap and cheerful devices.
    As this is not a topic for open discussion on this forum - PM sent.
  1. Retro Fitting a CD changer
    By Dizzy SaxMan in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 00:57
  2. What a day retro fitting
    By marc vectra sri in forum Styling
    Last Post: 31st July 2012, 22:11
  3. retro fitting afl
    By andy.l in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2010, 14:42
  4. Retro fitting rainsensor
    By sulten in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2009, 19:17
  5. Steering wheel controls retro fit
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2006, 20:47
can opcom program steering wheel buttons
vectra mid display male female
vectra c half can steering wheel scrollers
