Thread: Help with pick up points for turbo boost and oil pressure guages
    Regular Member Beebs's Avatar
    Livingston
    Default Help with pick up points for turbo boost and oil pressure guages
    Guys
    I've fitted a turbo boost and oil pressure guage to my 2007 Vectra 3.0 CDTI (184) and wanted to know the where pick up points for the sensors are.
    Can anyone advise?
    Regards
    Brian
    Regular Member benny's Avatar
    Feb 2006
    dudley
    boost presh you will have to drill / tap into a pipe / intake manifold .........oil presh is a real problem the oil presh switch is on the lower part of the engine near the bottom pulley i would say there bay a lot of room for a sensor .......
    Regular Member storm's Avatar
    Northumberland
    im waiting for my boost guage for my 1.9 8v cdti so will be interested to see where that needs to be fitted
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Quote Originally Posted by Beebs View Post
    Guys
    Can anyone advise?
    Regards
    Brian
    Boost not a problem , any vacuum pipe around the inlet manifold area but would need to see what type sensor and fittings you have for oil gauge as I dont think you can fit a sandwich plate to the vectra
    Feb 2006
    dudley
    Quote Originally Posted by daviek View Post
    vacuum pipe no good ....beeing that it would have a vac and not the boost he is looking for ...... there no small bore pipes on a 3.0 you need to tap into a larger pipe / inlet system after the turbo ....
    Norwich
    Trim : SXi
    Engine : 2.2
    I fitted one on an audi and tapped into the manifold think I used 1/8" bsp tap and a bit of permabond to seal the thread.
    ayrshire scotland
    Quote Originally Posted by benny View Post
    So obviously you dont know how a turbocharged engine works with that statement
    Livingston
    Ok Guys
    Thanks for all the posts on this. I'll attempt the boost gauge first and feedback.
    Cheers Brian
  1. boost pressure
    By aledjones_lex in forum Engine & Drivetrain
    Last Post: 6th March 2010, 14:47
  2. Boost pressure
    By Mark2.2 in forum Petrol Engine related
    Last Post: 23rd January 2010, 18:46
  3. What is a boost pressure valve
    By darveccy_c in forum Introduce yourself.
    Last Post: 1st January 2010, 23:52
  4. Z20NET Turbo boost pressure.
    By crabbitoldgit in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2009, 10:53
  5. Boost Pressure>?
    By Biddyy in forum Diesel Engine related
    Last Post: 5th April 2008, 02:35
