Results 1 to 10 of 14
Thread: steering light
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default steering light
    just started the car and i had a steering wheel with a ! symboland TC light on, tried to steer and it was heavy , so i turned the engine off and restarted and its all fine, what could it be, why does the steering light come on?
    Regular Member old cruiser's Avatar
    slough
    Might be worth as a precautionary measure to check fluid level mate.
    Cheers Pete
    Oct 2009
    Sandwell
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    is the fluid at the top of the engine bay? or is it the one under the bumper? or is that the brake fluid?
    i hope it is easy as fluid because im going away next month on a 180 mile trip
    slough
    The one under / behind the bumper mate ******, awkward to get to, what I end up doing is removing inner wheel arch protector screws , pull protector back a bit and unscrew reservoir cap and using e.g a white plastic tie wrap I dip it in to get a rough idea of where the level is as it seems to be hard to see the level from outside the bottle due to it's sort of creamy colour. HTH
    Cheers Pete
    Oct 2009
    Sandwell
    Cheers Pete
    i think its low then because when i fitted my new horn i took the bumper off and noticed that bottle and thought it was low i thought it was brake fluid, im sure this was a green colour last time i looked
    slough
    Sounds like it mate and I think you're right on the colour as it's not your standard power steering/ automatic transmission fluid stuff, so would suggest getting correct fluid from VX, incidently was it defo the bottle on the left side/ below airbox when looking from front of car you were looking at?
    Cheers Pete
    Oct 2009
    Sandwell
    when does the light come on when its below min or just higher than min???? or is it one of them where its half way and its just telling you to check it?? can i do the test with the pedals to see if it gives a fault code or is that just for the EML light?
    slough
    I would have thought when it's at min or below, if it's just a fluid problem then I suspect there might not be any codes present, bit like if the washer bottle is low on fluid .
    Cheers Pete
    Oct 2009
    Sandwell
    i dont suppose you know why the TC came on as well?
    slough
    Not sure why that came on as well, unless there is another issue going on, there is a possiblity of it being something to do with the abs as this is linked with the TC, might be worth checking that the abs connector is pushed home properly and /or giving the connector a clean and refitting.
    Cheers Pete
  1. Replies: 4
    Last Post: 18th August 2012, 08:58
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
