Results 1 to 10 of 13
Thread: Engine management light on cdti 150
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Default Engine management light on cdti 150
    as the title says it came on today and wont go out even after the car has been stopped and started a few times , what now ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If there is no limp mode I wouldnt be too worried, could be a sensor, or glow plug.
    But for piece of mind get the code read as there will be a code stored.
    Gazza4
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    cheers Gazza4
    Cambridgeshire
    Could be a couple of things mate. Could be water in the diesel filter or glow plug(s) faulty. Mine would come on when I start the car then go out a few minutes down the road. Got the codes read and it was faulty glow plug(s). Got them changed and it was only running on 1 apparently
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    Quote Originally Posted by parsco View Post
    what code did you get i tried the pedal trick but got nothing i have disconnected the battery just now i will leve it off for an hour
    Cambridgeshire
    I took mine to a mate who owns a garage, he has got the diagnostic equipment to check it. The pedal trick didn't work for me either mate
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    i like your exhaust video , i would like to decat mine but not sure which box is the cat
    Cambridgeshire
    Quote Originally Posted by peadar View Post
    I took both boxes off after the flexi pipe
    The CAT is the first (smaller) box after the flexi pipe and before the HUGE centre box.
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    thanks parsco i wasnt sure , my flexi is broke so i might cut it off and go straight to back box with s/s pipe FOC from work
    Cambridgeshire
    That's pretty much what I've had done mate, just got a pair of back boxes instead
    You get better throttle response and a niiiice sound
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
