Thread: Brake Light Question
    Planet Earth
    Default Brake Light Question
    As you know, on the brake light cluster, there are two brake lights, one above the other when the pedal is depressed.
    The warning light came on earlier saying "Brake Light".
    Checked the brake lights, as you do - (On the passenger side only the top light works, the bottom does not.
    However, this is the problem - both bulbs work fine - when you take the top one out and press the pedal, the bottom bulb comes on just fine.
    When you put the top bulb in, the bottom one goes off and the top one stays on.
    Any ideas folks??
    5 Post(s)
    You've only one brake light either side, and two tail lights.
    The upper tail light is also the brakelight, and should that fail, the lower tail light takes over the role of tail light / brake light.
    Planet Earth
    Cheers mate -
    Find the little b'stard of a culprit but no spare bulbs till tomorrow.
    Full Member Big Sig's Avatar
    fog light, passenger side isn't wired up. There's your spare
    Planet Earth
    Superb!
    Love this forum!!!
    Regular Member Robsey's Avatar
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    Quote Originally Posted by VSRI View Post
    Therein lies the answer..
    The side where both upper and lower bulbs have iluminated, then it is the upper one that needs replacing....Driver's side I presume.
    Because the upper one is on it's way out, check control has noted this, and so has illuminated the bottom one to compensate.
    Check control will flash up even if the bulb hasn't fully failed yet...just on the way out.
    Clever !!
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake/tail light bulb question.....how daft!!
    By marky2027 in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2012, 12:59
  3. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Hi just new but a big brake question
    By mikey68 in forum Handling & Braking
    Last Post: 25th May 2008, 18:39
