Thread: recurring juddering symptom- read on -inlet manifold?
    Aug 2009
    herts
    Default recurring juddering symptom- read on -inlet manifold?
    After a week or two, my car gets sluggish and holds back a bit on acceleration. On deceleration, in gear, and dropping in revs, it has an annoying judder (minor, but noticable). and decelerates rather quick.
    Now and then I take the intercooler pipe off the right side of the intake manifold, and then enter a good dose of carburettor cleaner into the intake manifold past the throttle body, and also a good dose of carburettor cleaner direct onto the swirl pots from the top of the engine, then put back together.
    Always get a good dose of white cloudy smoke out of the exhaust as the manifold clears through the exhaust.
    After this technique, the car runs, accelerates, nice and smooth, requires less pedal to accelerate, and then also on deceleration in gear, it does not decelerate so suddenly, and no judder.
    So, conclusion it is a gumming up inlet manifold?!?
    How can I do a really good permanent clean on this, or is it only to be resolved by a inlet manifold replacement?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Would this not be a sticking EGR at fault...?
    What state are your swirl tops in??
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Mines has developed a slight judder around 2,000rpm, hiccups between 2-3000rpm, and doesnt have the peakiness it once had, as said most likely the EGR valve as the swirl flaps wont cause juddering, they usually cause alot of smoke either low down or high up the rev range depending how they are stuck open - which means you can get away with for a bit but then it may start going into limp mode.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Aug 2009
    herts
    Right, had cleared the juddering yesterday.
    Went up to birmingham and back today, cruise control all the way, now back on roads at 30 mph with gear changes, it is juddering again..
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If the swirls are covered in oily gunk and just messy, then the manifold wants changing (£170 or less on ebay) along with a new inlet manifold gasket and a new style fiat EGR semi blanking gasket and you should be 100%.
  1. Inlet Manifold
    By Quirrel in forum Engine & Drivetrain
    Last Post: 23rd January 2012, 12:59
  2. inlet manifold
    By redross555 in forum Engine & Drivetrain
    Last Post: 13th February 2011, 14:52
  3. Going To Fix My Inlet Manifold!
    By corderz in forum Engine & Drivetrain
    Last Post: 12th February 2011, 09:29
  4. Inlet Manifold
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2009, 21:15
  5. inlet manifold
    By 30ltr nutter in forum Engine & Drivetrain
    Last Post: 27th May 2008, 17:21
