Thread: Engine oil light
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    Default Engine oil light
    hi my car seems to be using up alot of engine oil i topped it up about 3-4 weeks ago when the light came on and last night after a bit of heavy driving engine oil light came back on and i topped it up again. is there a underlying problem or is this normal it also looses coolant water and needs regulat top ups. kind of getting me worried at the moment. its a 3.2 v6
    Thankss
    Bedfordshire
    I would say you have a problem my old gsi never needed topping up oil or water between services. Can you see any leaks or stains on the driveway ?
    If mines driven carefully it uses very little/no oil. Give it a good kicking and it starts to use a bit of oil. I think the high revs just push a bit of oil pass the rings. Also, all engines are different. Some use oil, some don't. I think VX starte that its ok to use 1000ml per 1000 miles. Over that is a problem.
    Coolant water? Check everywhere for leaks.
    Mileage : 000
    My 3.2 uses little to No oil even when my right foot is a bit heavy. I used to have a Sierra that driven normaly it used No opil. But if I belted it. It used more oil. So you mighjt not have a problem. But worth any investigation, just incase.
    Sep 2009
    luton
    Mileage : 100000
    thanks for your replies guys, i cant see any leaks or visible oil stains on my driveaway thats what got me confused, where is the oil going? and coolant loss has been there since ive brought the car, going to get it checked up this weekend and again cant spot any leaks from pipes coolant tank etc.
    Regular Member jlock's Avatar
    Jun 2009
    London
    Vehicle : BMW 525i
    Trim : M-Sport
    Engine : 2.5l Straight 6
    I know mines a 2.2 but my oil light has been on for a wee while now but everytime i check it its full :s
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Engine and Spanner Light Before I Start The Engine
    By corderz in forum Engine & Drivetrain
    Last Post: 24th March 2011, 18:48
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
