Results 1 to 10 of 16
Thread: Aircon problems
    Regular Member Steevo's Avatar
    kent
    Default Aircon problems
    Hello
    Put my aircon on earlier and its not gettin cold at all possibly even slightly warmer with it on. Can't remember the last time i used it the light comes on but nothin.
    Is there a fan or somthing which should cut in when you switch it on because i can't hear anything?
    Any help or suggestions would be great
    Its an 07 sri hatch 1.8vvt
    Thanx
    Steevo
    Regular Member PauloMcGuinee's Avatar
    Jul 2009
    Milton Keynes
    Does your car have ECO mode? I have the Climate Control and when I bought the car it was in ECO mode which turns off the aircon to save fuel.
    11 Post(s)
    Quote Originally Posted by Steevo View Post
    Needs to be used regularly (even through winter) to prevent the rubber seals from drying out and the refrigerant escaping.
    kent
    will i b able 2 see if it has leaked anywhere?
    Thanx
    11 Post(s)
    Thanx
    Not generally, no. If you've got a Kwik Fit local to you, take it along and they'll hook it up to their automatic machine which will test for major leaks, and if none are found will replenish the refrigerant and oil to the correct quantity and charge you something like £30 (or less). If the find a leak they won't charge you a penny.
    http://www.kwik-fit.com/about-air-conditioning.asp
    Regular Member R-ford_Vec_C's Avatar
    St Helens
    Smashing, will take mine along this weekend after I've valleted her, been blowing normal cold air ever since I bought her 2 months ago!!
    11 Post(s)
    Another thought, as your car is an 07, is it under 3 yrs old, and done less than 60,000 miles?
    If so, and the AC has a leak, then maybe the remainder of the manufacturers warranty will pay for the repairs.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    As said it's good to use the air con for at least 15mins a month even in winter. Regas should sort it though
    Jul 2009
    NEWPORT
    How can you turn the Eco mode off any help cheers
    Regular Member gaz4d's Avatar
    Glasgow
    i have exactly the same issues.
    the cheapest i could find near Glasgow for a re-gas was £50 at kwik-fit
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  3. Aircon Help
    By 3.2wales in forum Vectra C / Signum Troubleshooting
    Last Post: 27th April 2011, 01:42
  4. aircon problems guys and gals any help
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2010, 22:01
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
