Results 1 to 2 of 2
Thread: Airbag problem!
    Regular Member mileff's Avatar
    Bulgaria
    Default Airbag problem!
    Hi guys,
    Since 3 days i have a problem with the airbags. The airbag lamp is on every time i start the engine and do not turn off.
    We saw the fault code via diagnostic interface but couldn't remember it . It was something related with "child seat detection". After some browsing in the fault codes the only ones related with this name are these:
    B2583 Child Seat Detection Circuit Short to Ground
    B2584 Child Seat Detection Circuit Open
    B2588 Child Seat Detection Circuit Short To Battery
    What doest child seat detection means. What the problem could be?
    Thanks in advance
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    There is a transponder built into Vauxhall supplied child seats, that will communicate with the airbag circuit.
    If a seat is present, then the airbag on the passenger side will be turned off, and a symbol on the dash should illuminate to tell you that the child seat is detected.
    I can only assume that a wire to the seat transponder receiver module has become shorted or detatched, dependent upon your exact message.
    Did you get the fault code reset, as sometimes this alone may clear the fault.
  1. airbag light problem
    By gangleyshag in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd May 2012, 22:31
  2. Airbag replacement - NSF (front passenger airbag)
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 19th February 2011, 21:12
  3. Airbag problem
    By asd in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2010, 08:47
  4. My 1st problem....Airbag Help...Please
    By Warrenmole in forum Vectra C / Signum Troubleshooting
    Last Post: 5th July 2008, 20:57
  5. airbag problem
    By patrick1062 in forum Bodywork & Interior
    Last Post: 26th June 2008, 14:20
airbag vectra problem
