Results 1 to 10 of 29
Thread: emission...
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Default emission...
    Hi Guys
    My car just had its MOT.. and.... it failed.. on:
    CO2 emissions to high.. (legal is 0,2 was/is 0,432)
    What to do?
    Engine : 2.2 Direct
    think its called Monooxide in english..
    Mileage : 000
    Might be the CAT or the Lambda probe. Or even the tempreture sensor telling the engine that it is still too cold. Thus the ECU will tell it to over fuel all the time ( like running with the choke on all the time). Thus are several possiblities to look at.
    Engine : 2.2 Direct
    It might not have been warm.. as ive only drove like 2-3 miles to the test center.. and had to waight for 15 minuts until it was my time...
    but when ive got the car back it showed about 85 degrees in water temp...
    Can i somehow test the lambda probe? or is it just about checking for error codes?
    Mileage : 000
    I don,t think reading any codes will be able to tell you if the Cat is worn out though.
    We had this happen on the wifes Vectra B several years ago. I had put a new CAT on as the old one had fell to pieces. It failed on the emissions. Belive it or not the CAT was Duff/no good. They put another one on and it passed. I got my money back off the "old/duff" cat though.
    I wonder if reading the codes for the Lambda might show something though.
    When you say it might not have been warm. They should have waited untill the "machine" said it was hot enough, or waited till the tempreture gauge showed normal/working tempreture. Otherwise the car would not be measured at it,s "best working condition".
    Engine : 2.2 Direct
    maby i should get my dad to take it for a long spin.. (30-40 KM) and then another testcenter...
    yes it only showed about 80-85.. thats not warm. so could be that..
    Mileage : 000
    Try some "carb cleaner"/ fuel treatment, then give the car a good drive, that might "clean it out" and help the emissions.
    Don't wear your slippers to the test centre Mr Ken.
    You need heavy boot's & a nice run to get things warmed up a bit hth ...............
    Engine : 2.2 Direct
    humm ill think i send my dad then his a bigger man than me 30-40 KG more than me.... (if a heavy foot it neede....)
    just read out faultcodes.. there no error on the lambdasensor..
    Full Member Big Sig's Avatar
    Make sure you have a fairly empty fuel tank, empty a load of fuel treatment into it. Give it a hard fast run, maintain high revs for a while. Then retest it.
  1. Please help emission lamp on!!
    By cigar in forum Vectra C / Signum Troubleshooting
    Last Post: 1st June 2009, 19:43
  2. Emission light on.
    By ExclusivDoug in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 10:36
  3. Another emission light on
    By soulie in forum Engine & Drivetrain
    Last Post: 27th February 2009, 19:38
  4. emission light help!
    By platty in forum Engine & Drivetrain
    Last Post: 22nd August 2008, 18:09
  5. help with emission light
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 10th July 2008, 02:02
