Hello everyone!
It was not clear to me
Can this mod work if there is no digital broadcasting in my country
Will the DAB unit send a signal to the cdc40 opera signal to mute?
please, any information
sorry for my bad english
Thanks a lot, everyone!
It will work even without the signal. That's how it works on my car.
Thanks for the answer!
Did you put a switch? or just pierced the AUx connector in the wiring?
Just do not see the point in the switch if there is no digital broadcasting.
Thank you!
Can anyone point me in the right direction for where I can buy the correct components to do this job?
I tried before by the aux in port I had was awful and difficult to wire.
Hi folks sorry to drag this up again, ive basically done this without the switch, cut the dab audio and ground cables just short of the stereo connector block and soldered a 3.5mm jack to them instead, the audio from phone is playing but very faint as someone else said earlier in the post, can anyone give an answer as to what ive done wrong! My dab box is one of these that has crashed when they tried a new dab signal and ive never had it fixed, could that be the problem? Thanks for any info!
The DAB module needs to have a working signal otherwise you will not get sound. When there is no signal the sound is muted on the stereo itself.
To get the DAB module working it just needs to have the module reset via Tech2.
Once your module is working and has a signal the sound should pass through.
Sent from my SM-T713 using Tapatalk
Thanks very much for the reply, thats what i was thinking but glad you confirmed it. Been looking for someone local to hull with tech2 but been too busy to give it too much thought!
I did it in the Astra, but had no joy, needs to be a headunit that takes the aux I’m just waiting to get a few bit back to fit the dab in it
Sent from my iPhone using Tapatalk
