Thread: Got a quick question...
    Northampton, UK
    Default Got a quick question...
    302mm GSI / 2.0T brakes would work fine on any Vectra C right??
    I sold my old 302's on eBay a few months a go and the guys just got round to fitting them, but says the garage fitting them can't get them to work.
    They're saying something like there's not enough "boost pressure"?
    Now I know they worked when I sold them as I obviously had them on my car before upgrading.
    The cars a pre-face diesel, that's pretty much all I know, but why wouldthey suddenly no longer work??
    Any ideas?
    Sunny Dartmoor
    Maybe they've fitted them upside down,that could be the reason.....
    Northampton, UK
    Problem is I obviously can't have a look my self unless I drive all the way to London... But surely, any garage should know what to do?
    Sunny Dartmoor
    They should but i know a few members have had the same problems so maybe its an easy mistake to make......
    Northampton, UK
    I guess. I've emailed the guy and gave him a few suggestions.
    They should fit any Vec C thou right?
    Sunny Dartmoor
    Yeah they'll fit Nick,can't see it being anything else if you ask me,keep us informed m8........
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I have 302 calipers on my 2003 2.2dti, hth
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    I have read about guys on here and elsewhere that have upgraded to 302mm and had no problems.... if it were an issue then you would have had problems going up to a bigger size on your car..
    Do you think that as he has had them for sometime they may have seized up a little and just need working out.. maybe there is a vacuum leak, i have only heard of a car requiring extra boost pressure in the braking on the hot rod circuits..
    Not sure about his garage though... as you say, they should know what to do..
    Full Member Big Sig's Avatar
    Probably upside down as already said. It makes it very difficult to bleed them fully as the nipple isn't in the correct place leaving air trapped.
    But yes they will work on any veccy.
    Northampton, UK
    Cheers guys for your comments and replies.
  1. quick question
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2011, 21:39
  2. Quick Question - Need a Quick Answer if Possible
    By RobW in forum Suspension, Wheels & Brakes
    Last Post: 8th February 2011, 23:55
  3. DAB Box quick question
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2009, 01:25
  4. Quick Question
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2008, 22:14
  5. A quick question
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2007, 14:53
