Results 1 to 10 of 13
Thread: Normal For Back Pads & Discs To Wear Before Fronts
    HAMPSHIRE
    Trim : SRI
    Engine : 3.0 cdti
    Default Normal For Back Pads & Discs To Wear Before Fronts
    Hi
    Im new to Vectra C Club and have made the change from a astra coupe into a Vectra 3.0 v6 cdti facelift sat nav(58 Plate).
    I dropped the car into a local Vauxhall dealership concerning a noise from rear.
    I was informed that the rear tyres had a lip causing noise, they also dropped the bomb shell that the back brakes had 95% worn and needed replacment pads and discs.
    The car has only done 23k (only had 7k when i purchased) but the fronts are only 50% worn. 99% of usage is motorway and I dont think I have ever driven with the handbreak on.
    Any help and thoughts would be great.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Just replaced my rear pads and my fronts have about 30% left.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    my rears were just replaced at about 60k shortly followed by the front's, as the disk & pad kit is cheap i went that way..
    HTH
    Midlands Mod Shop - NFFC.
    HAMPSHIRE
    Trim : SRI
    Engine : 3.0 cdti
    I tought it was me loosing the plot and Vauxhall trying to pull my pants down.
    HAMPSHIRE
    Trim : SRI
    Engine : 3.0 cdti
    I was quoted £204 for the back Pads & Discs
    @home
    Engine : 1.9 CDTi
    Quote Originally Posted by Geordieman View Post
    how much?!!!
    My pads cost under £30 and I think the disc/pad kit is about £70. Can be done in an hour.
    Trim : Get a
    is that supply and fit as trade club prices are about £60.00 a kit.....
    HAMPSHIRE
    Trim : SRI
    Engine : 3.0 cdti
    That was through dealer supply & Fit
    havent priced up for parts only through them yet (as you can imagine I was keen to get out with my pants on)
    As I said new Vectra all tips welcomed.
    @home
    Engine : 1.9 CDTi
    why not do them yoursself? They are easy to do if you have the tools..
    long nose pliers, jack, axle stand, rachet with hex bit (cant remember the size). There's a how2 on here as well.
    Premature rear brake failure on the original set is VERY common on the Vectra
    The noise you heard was the discs, this is normally also accompanied by a vibration when braking
    I have claimed every time for this
    What you need to do is ask for the fault to be looked at by way of a road test, demonstrate it to the Service Manager if need be
    The noise and vibration is usually enough for this person to agree there is an issue
    The matter is then raised as a warranty claim
    Normally the rear brake pads are about 80% at 15K miles, but this causes damage to the first set of discs
    Sadly this is the typical life span of rear pads (15K miles)
    The replacement discs will last longer, but only to about 15K miles / 30K miles
    Front pads should last you to about 20K miles, the front discs about 90K miles
  1. changing discs and pads, pushing pistons back.....
    By taffy bhoy in forum Suspension, Wheels & Brakes
    Last Post: 9th October 2012, 22:33
  2. 2.2 dti sri back discs n pads
    By Dazg-sri in forum Troubleshooting
    Last Post: 13th March 2012, 14:02
  3. Is this fuel pump problem normal wear?
    By surreyfrog in forum Engine & Drivetrain
    Last Post: 19th May 2010, 21:23
  4. Replies: 1
    Last Post: 21st October 2008, 15:11
  5. Can you fit 314mm discs to replace discs on back wheels of a GSi 3.2???
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 21:10
