Thread: Y30DT 3.0 V6 CDTI cambelt change
    Default Y30DT 3.0 V6 CDTI cambelt change
    Could someone please give me the FULL service details or reference on TIS for a cambelt change
    I want to present this to my local dealership and have a SERIOUS argument with them
    I have now asked four different dealerships about what they actually do during a cambelt change on this engine, although they have all quoted the same labour time of 6 hours
    One questioned 6 hours and came back advising it may only be 3 hours
    However, one answered the question correctly, listing the cambelt PLUS the additional work that is required after fitting a new cambelt
    We all know the cambelt change can be performed and completed in 2 hours, so what is the other 4 hours for (and member Celes, be quiet as you know the answer as well now!)?
    Failure to complete this additional work almost certainly causes the blocked SCV issue
    Equally, since other people have reported they have had a cambelt change and then this same blocked SCV issue within 6 months I believe there is enough evidence for VX to wake up and put an advisory to all dealerships about this
    Full Member Big Sig's Avatar
    Hope this helps? I don't really know how to use tis but this is all I can see. As yet I haven't seen any notes refering to further work.
    Interesting that it is 5 hours
    The details only show 2 rollers, there are 3 (one tension, two guide)
    My dealership cut some time by removing the air filter housing, giving better access to the area, although they could have refitted it properly!
    Perhaps the revised cambelt procedure is in a service bulletin (like the one for the blocked SCV)?
    There could well be 3 rollers included. I may have missed one off as you have to select the bits yourself when adding up the times. It would add another half hour or so to the job.
    J435200 = 1.3 hours
    That makes the total slightly over 6 hours
    My dealership managed it in 4 hours, makes me wonder how members here manage it in just 2 hours (although no stopping for tea breaks and interuptions probably!)
    As above, see if there is a field remedy for cambelt
    I cannot see anything but then you don't really search like that. I cannot see anything at all other than a replacement for the cambelt. No notes etc relating to anything else - it could just be me though.
  1. Y30DT Cambelt / Water pump change
    By dshelton999 in forum Engine & Drivetrain
    Last Post: 23rd February 2013, 23:13
  2. 1.9 CDTI (150) - Cambelt Change; What Do I Need?
    By DanR in forum Engine & Drivetrain
    Last Post: 24th November 2011, 17:37
  3. Cdti 150 cambelt change
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 26th January 2011, 14:51
  4. CDTI 120 Cambelt change
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 29th May 2008, 21:02
  5. cambelt change CDTi
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2008, 19:29
vauxhall vectra 3.0 v6 cdti cambelt
