Thread: Help Please!! 1.8 Gearbox...
    Oct 2007
    Shropshire
    Default Help Please!! 1.8 Gearbox...
    Hi,
    My gearbox has gone, hole in the bottom! I need to know the code for the gearbox on a 1.8 vvt. Is it F18? Is the gearbox on a vvt the same as on a 1.8 16v?
    My car is a 2007 1.8vvt
    Oct 2007
    Shropshire
    Also is it engine out to change it?
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    hi therei amnot surewhat gearbox it is but you dont need engine out to change it but it is a big taskfora diy but with the right tools and equipment it isnot too bad
    Jan 2010
    kilmarnock
    Thumbs up
    The number that you need is undet the final drive unit look in from passangers wheel arch (wheel off) you will see a cover plate with 9 bolts in it the number is etched on this part it will look something like
    a341c34f1739
    the part in the middle (f17) defines type of gear box and the rest make up the ratio gear setting ALSO IS THE HOLE IN THE COVER PLATE AT BOTTOM IF SO YOU CAN GET FINAL DRIVE/ DIFF REPAIR KIT FROM DEALER £90 INC NEW COGGS ECT
    alhaw
  1. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
  2. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 18th August 2011, 18:12
