Results 1 to 10 of 18
Thread: egr valve sealing gasket 1.9 cdti 150
    Regular Member kev77's Avatar
    nottingham
    Default egr valve sealing gasket 1.9 cdti 150
    hi just picked both of these and wondered if i needed to fit both of them ?or just the one e.g the oval one. got both just incase .if anyone has fitted both with no problems could you let me know thanks alot.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Only one is specified by Fiat but good results have been had by members after fitting both - all down to choice but you may as well do both while the egr is off
    nottingham
    thanks for that just wondered if there would be any problems by fitting both and what sort of results should i expect?
    Mar 2007
    Southport
    I've only fitted the big one & my local Fiat agent wants a minimum order of 10 gaskets so I'll be making the oval one myself as soon as I get round to it. The gasket helps to keep the cr@p out of the egr & the engine pulls better from low revs with it fitted
    nottingham
    minimum order of 10 takes the **** i just phoned up on tuesday and they were there today might be worth trying another agent
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    I have both fitted, no problems. Been checking the build-up behind the oval one periodically and there has been none. Get 'em both on.
    nottingham
    have you noticed any difference
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by kev77 View Post
    Not massively, but its not really about that, its keeping the soot build-up down to a minimum.
    nottingham
    just didnt want power to decrease have you had a new inlet manifold or is it still the original one didnt know if it was worth using the wynns egr3 air inlet cleaner first
    Jun 2009
    Nottingham
    Kev,
    I'm in Nottingham too and need to do my inlet manifold. Which Fiat dealer did you go to for the gaskets? Are you changing the manifold yourself or getting a garage to do it? Have you had any quotes from anywhere?
    Andy
  1. **Urgent help required - Idle Control Valve gasket**
    By Bloicy in forum Engine & Drivetrain
    Last Post: 23rd April 2012, 18:13
  2. Replies: 21
    Last Post: 2nd May 2011, 20:20
  3. Help! 3.2 Idle Control Valve Gasket Needed (Leeds)
    By Hedgehog70 in forum Engine & Drivetrain
    Last Post: 25th May 2009, 12:39
  4. part no. gasket for erg valve 1.9cdti 120sri
    By jpdtm in forum Engine & Drivetrain
    Last Post: 15th May 2009, 20:17
  5. Valve cover gasket
    By F4LSE in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2009, 15:15
sealing gasket 1.9cdti
1.9 cdti egr seal
