Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: 2.2i direct timing chain
    Regular Member LEEROB695's Avatar
    scunthorpe
    Default 2.2i direct timing chain
    Got my 2.2i direct signum last thursday from a local car supermarket 2006 76000m FSH
    As soon as i got home i found this forum and i found out about the recall on the fuel pressure switch and got it booked in with my local vauxhall dealer to look at
    took the car down today and VX replaced the offending article under the recall
    they then advised me that the cam chain had some noise and in there words they "reccomended replacement"
    They let me have the original copy of the jobsheet advising this for me to take to where i got the car from
    I have just took the car back and showed them this piece of paper and they say that they have never heard of cam chain problems on the 2.2i direct i told them to google it
    they said it was the main dealer just trying to get extra work in!
    although i have 3 month warrenty from the car supermarket and a further extended 2 year insurance warrenty i am still a little worried i told the salesman that if this timing chain snaps in the next 3 month i will be gunning for him personaly as i have told him about the POTENTIAL problem beforehand
    Having just read the policy it states that belts are covered if they are changed to manufacturers standards so my question is what it the reccomended time to change a chain on this engine as if it goes this warrenty mignt not be worth the paper it it written on
    Also should i be worried "Personally i cant hear anything but im no mechanic"
    what should i do with regards to the garage i bought it from as i feel i have just been fobbed off
    any ideas welcome
    thanks in advance
    thanks in advance
    Regular Member benny's Avatar
    Feb 2006
    dudley
    try www.z22se.co.uk for more info ....
    Jan 2010
    glasgow
    hi i heard the chain prob was fixed on the 2.2 direct on or after 05 but dont qoute me on that i think the chain change is 100k miles but now here is the but i have heard of peeps having chain probs around the 04-50 year why dont u take it to a diff garage and see what they say telltale signs is a noise firts start in the morning then it will fade away
    Regular Member doughy's Avatar
    Jan 2010
    Wisbech, Cambridgeshire
    Trim : Exclusive
    Engine : 1.8VVT
    Mileage : 53000
    I thought this problem was for the z22se engine only as it had a oil jet undersized which blocked up (recall to fix this)and the 2.2 direct z22yh engine did not suffer this faliure.
    If you can't hear any rattling noises then I expect he cannot either, enjoy your car and stop worrying
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    The z22yh is still affected by this problem, replaced loads at work, Have an 07 vectra sri in at the mo and the chain has slipped at 70k!!!!
    If its noisey get it replaced or it could result in an engine, Dont want to frighten you but just dont ignore it...
    Feb 2006
    dudley
    Quote Originally Posted by doughy View Post
    i dont know much about these engines either ... but if people do have z22yh's i would be looking into changeing the oil more often possible looking at getting the tenstioner changed or at worse getting a new kit fitted ...
    11 Post(s)
    Quote Originally Posted by benny View Post
    possible looking at getting the tenstioner changed ...
    The tensioner has been revised. Mine went recently and the field remedy advises to fit the one that's fitted to the 2 litre turbo.
    See http://www.vectra-c.com/forum/showthread.php?t=104735 for more info.
    Jan 2010
    Trim : Exclusive
    Engine : 1.8VVT
    Mileage : 53000
    Fair enough i think about regular oil changes, but if its not rattling would you say its in ok condition? Do they rattle first as a rule?
    Regular Member davidlewis24's Avatar
    bridgend / wales
    Quote Originally Posted by alanv6 View Post
    my z22yh 2.2 direct 06 plate slipped last month 57k its still 100% affected
    norn iron
    deffo, mine slipped at 45000
    by the way, do anything benny says, 2.2 chain god
  1. 2.2 direct timing chain
    By Paddy in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2012, 21:31
  2. 2.2 direct.timing chain rattle.
    By Dobs in forum Engine & Drivetrain
    Last Post: 4th April 2012, 20:47
  3. 2.2 direct timing chain
    By degsy11 in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2009, 20:10
  4. Timing Chain 2.2 Direct
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 15th January 2009, 10:59
replace timing chain on a vauxhall vectra 2.2i
z22yh timing chain recall
